It will not spin
The tub will not spin the water out of the closes. The water drains but the tub does not spin.
  • 721 Answers
Probably a bad transmission.
Posted on Jul 15, 2009
Mayta mav275aw washer does not get all of the water out of clothes
The drain pump on those are fairly common to have problems...
It could be that the washer is not getting all the water out of the tub so the close stay wet. here's a link to the part:
Drain Pump 35 6780
It could also be that the tub is not spinning fast enough to squeeze water out of the clothes... Does it seem to bee spinning well?
Jun 11, 2014 | Maytag PAV2300 Top Load Washer
Does not want to drain the water after washing circle
Hi.
Start checking the drain hose at the back, and the hose attached to the drain pump, located at the bottom of the appliance. After that access the control panel and clean the hose attached to the pressure switch. Also check the lid is closing well. Those are the only easy fixes.
The first parts to check are door latch and drain system.
The timer performs an additional check on the door latch before advancing to spin. The door switch it is tested by jumping its contacts, or by reading impedance to check if the switch is opening and closing the circuit (you will need a multimeter).
About the drain system,
if the machine does not drain, then the cycle will not advance to spin.
The electronic control checks the input from pressure switch (which detects water level) before advancing to spin part of the cycle. If there is a drain problem, then the machine will not spin.
The first step will be accessing the drain pump.
Kenmore top loaders' washer pump is accessed from the bottom side of the appliance.
Get ready to collect the water that will come from inside the tub.
Check also the drain hose at the back. Ensure that the height of the hose elbow is respecting the specifications indicated in manual. A wrongly placed hose will result in water going in the washer drain pump and tub, causing drain problems and no spin.
If lid switch and drain lines are OK, replace the pressure switch, which is difficult to test (it is tested reading impedance with tub full and empty. Before replacing the switch, you can try cleaning it and blowing into the switch pipe. Check also motor before replacing the switch. The switch is connected to a long rubber hose and it is located in the control panel.
Below an article about the no spin problem. If the problem is coming with no drain, check drain filter, drain hose at the back. If they are OK, the pressure switch may need to be replaced or the pump may be defective.
Here the general troubleshooting for no spin: If you have no spin there may be different reasons behind the problem.
Enter full model number here (the one written on tag) to get all parts and diagrams for your washer.
Regards.
Ginko.
Mar 19, 2011 | Speed Queen AWS75NW Top Load Washer
The machine fills and will not start agitating unless the lid is open and closed several times.
The most likely failure is the water level pressure switch or a failed lid switch. If the washer will drain and spin then it's not a failed lid switch. If it will not drain and spin the likely failure is the lid switch.
The water level switch (pressure switch) has 3 wires attached to it, V (violet), P (Pink) and a T (tan) wire. When the tub is empty of water, contact V&P are closed to allow the tub to fill with water. Once the water level reaches the desired setting, contact V&P opens and then contact V&T closes to start the motor agitating. So, with this said if you were to unplug the washer and remove the wires from the water level pressure switch and test to see if terminals V&T is closing by using an ohm meter would indicate if the contact is closed or not.
Jan 12, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a WM2277HS TROMM Washing Machine and at the end of the cycle the water does not drain nor does it spin. Therefore, the rinse & spin cycle only rinses but does not drain the water nor spins. ...
Sounds like a bad lid switch. Check to see if you hear a "click" from the switch when you open and close the lid. If you do not, then you should replace the lid switch.
Nov 26, 2010 | LG WM2277HSW XL Front Load Stackable...
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Water leaking around machine
ck belt or replaced belt is designed to slip to a point if belt grabs too quickly the tub rpm come up to fast not giving tub time to drain down far enough to prvent climbing over the side also be sure drain hose is not plugged reducing water flow to drain
Jun 04, 2008 | Amana ALW880WH Top Load Washer
Tub doesnt spin after wash or rinse cycle
if it goes thru the wash cycle , is NOT a belt problem , what could be is a sensor switch located underneath where the door closes , its like a latch switch for security when it goes to spin, hope its helpful AJ
May 14, 2008 | Washing Machines
Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Apr 30, 2008 | Washing Machines
Water wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 27, 2008 | Hoover H140E Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
