Question about Whirlpool Refrigerators
Why water is dripping, i do not use the ice maker, it's either freezes everything or dirpping water
  • 585 Answers
If you have no desire to use the icemaker, simply turn off the water supply by following the supply line to the valve. (the valve you're looking for has a tiny little "T" handle) The refrigerator has a solenoid valve at the back that admits water as needed for the icemaker. If the valve gets a contamination such as rust, it will leak. Replace the valve, or have it replaced if you wish to use the icemaker.
Posted on Jul 15, 2009
  • Bruce Volkers
    Bruce Volkers Jul 20, 2009
    Did you get your issue resolved?
Ice maker water freezes before getting to Ice maker
likely you have a bad water valve where the water goes into the fridge. The valve is not sealing all the way and the water is dripping even when it closes allowing the water to freeze up
May 17, 2012 | Frigidaire Refrigerators
Water driping inside from ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top mont refige; ice maker works but allows water
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it can freeze and block the tube or keep dripping into the ice mold. . You can take the water line off the valve and watch to see if it drips.
Sep 11, 2009 | Refrigerators
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker filling with water but not freezing into cubes.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker freezing up, no ice, cannot control thermostat
If it's locking up, it could be the main gear drive with a broken gear. On some models you can replace the motor module and others you have to replace the ice maker.
OR if it's freezing up with ice--- If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Here's a diagram and parts for your ice maker.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FRS6R5EMB0&productCategoryId=0165000&brandId=1428&modelName=REFRIGERATOR&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=R0502180&backToLink=Return%20to%20Sub%20Components%20list
Aug 25, 2009 | Frigidaire FRS6R5EMB Side by Side...
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
