Question about Refrigerators
The water is warm and there is no ice - Refrigerators
  • robert3508 May 11, 2010
    1. is your frzr temp around 0 to +5 degrs. ? 2.are your setting set to factory/normal ? 3.second thru fourth cups of water are normally cool and not ice cold. i need more info
    Champion:
  • 363 Answers
What brand is it
Posted on Jul 21, 2009
Have 4 yo Newair under counter ice machine. The ice machine runs through its normal cycle but there is no ice made only cold water is dumped into the ice bin.
According to Newair, the ice maker may be leaking coolant, which requires a "qualified technician" to fix. Check to see if there are any oily substances leaking from the device. Also, the device may be in too warm of an environment (but if it has been working in the past where it is placed now and that environment's conditions haven't changed, I personally don't believe this is the issue). On another note, the water in the reservoir may be too warm, so try filling it with colder water.
http://www.newair.com/articles/how-a-portable-ice-maker-works/
May 18, 2017 | Dishwashers
Freezer temp flashing post removal of ice bucket components - is this why?
Possibly because of ice build-up under ice bucket, a common occurrence. It needs to be removed and wiped off periodically. And the ice sometimes makes it difficult to remove the ice bucket, so you may need to use some warm (not hot) water in a spray bottle (squirt warm water under the seam at bottom of bucket) to get it loose. Of course, this is all assuming the bucket is the type attached to the door.
Dec 15, 2014 | Refrigerators
Water keeps overflowing out of the sump trey continue running
Replace water fill float valve is letting water seep buy during freeze cycle and it will not make ice due to water too warm
Jul 26, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Freezer vents full of frost.around every two months. Top refrigerator warm up. I resolve by removing all frost and ice from the freezer vents to clear cold path and get it to work. Possible problems...
First try melting the ice with hair dryer. See drain tube going to pan under frig? It can get clogged/frozen with ice. I cleaned mine with very warm water shot out of a water pik. Or u can hair dryer it, then pour warm water on the little pan that holds the drain tube. Be sure that tube is clear for draining.Otherwise, more ice at vents.
Aug 22, 2011 | Amana ARB2217CSR Bottom Freezer...
LG LFC21760ST: In freezer area floor, there is ice build-up. Water is leaking from the back wall where two horizontal openings are (near the center). We've turned off the water for the ice maker but this...
If you shut off the water to the ice maker, the only other cause is a plugged drain hole. Somewhere around the bottom of your freezer there will be a small hole that allows moisture to drain out of the freezer and into a catch pan under the refrigerator. If this hole is plugged with ice then the water has no where to drain but out the door of the freezer and puddling on your floor. The water you see dripping is condensation that has built up in the freezer itself.
To fix this problem, you need to dislodge/remove the ice from the bottom of the freezer and the hole. I have had the best luck using warm water with a turkey baster. Another alternative would be an ice pick or any type of utensil that can be safely used to dislodge the ice from the whole and the bottom of the freezer. I prefer the water method because it is the safest. Ideally what you want to do is force warm water in small quantites down the hole. This will melt the ice and reopen the drainage. You then need to remove any ice around the bottom of the freezer using warm water. When done make sure to dry the bottom of the freezer.
May 05, 2011 | Refrigerators
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Kenmore Refrigerators
Ice maker not working
For the missing arm you should contact the company via your dealer. The water pipe must be clogged with ice and dirt preventing water to flow to the ice maker. If you have real patience, you can fix it but might take some time. Take some warm water and pour it slowly through the pipe in the opposite direction of water flow. The warmness of water will melt the ice and clear of the dirt. Sometimes it may take hours, but the time taken depends on the amount of ice in the pipe. Since this is a matter of just 2 months, i assume it won't take much time.
Jul 05, 2010 | Amana ABB1927DE Bottom Freezer...
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Need to clean ice cube dispenser
yes warm soapy water followed by cool clean water.
Mar 28, 2008 | Frigidaire FRT17B3A Top Freezer...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
