Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Broiler works on a GE JBP79 but oven will not fully ignite. It sputters and never reaches temp requested. I have replaced the regulator. Same problem.
  • fowler345 Jul 15, 2009
    Again, the gas to the oven, not broiler, seems to be going off and on. The igniter glows and the oven lights, than goes out, relights, goes out and so forth.
    Can it be the igniter or the gas valve to the oven burner. Again, the broiler and burners work fine.
    President:
  • 1,136 Answers
Hi, You will need to change the ignitor for the bake. It has gotten weak and will not properly opeen the gas vlave. If you remove the floor panel inside the oven, you can see the ignitor and see how it attached to the burner assembly. If you will get me the entire mdel #, I can look this up and get you part #'s.
Please let me know if I can assist you further.
Vic
Posted on Jul 15, 2009
  • Victor
    Victor Jul 18, 2009
    Hi, Please let me know if my response helped you at all or if I can assist you further.
    Thanks
    Vic
  • 3,741 Answers
Diagnosing a non-sparking can be frustrating. With some simple understandable of how the module and related parts work, diagnosis can be made easier.
The module receives 120VAC from the ignition switches are wired in parallel, meaning that each switch can activate the module. Power (L1) comes into the first switch then jumps tot eh second, onto the third, and so on. L1 passes through the switch then outward to the module. The outgoing L1 is weird the same way as the incoming, with the exception that it goes to the spark module. With this understanding, ignition switch is turned on individually. Should one switch appear to be nonfunctional, check the switch. Should a couple of switched appear not to be working, check for loose wires between the switches. This only applies to non- reignition type systems.
The module, once it receives the L1 voltage from the switches, energizes the coils to produce approximately 12000-14000 VDC to the burners. The coil sends the voltage out via the igniter wires to the igniter where the spark jumps to the burner base. Voltage then passes through the burner to the grounding strap, through the chassis to the opposite grounding strap, to the burner base. The voltage jumps from the burner base to the igniter (that's right from the base to the igniter), passing back through the igniter wire, to the coil, thus completing the coil operation circuit. The coils in the module are balanced based on impedance or resistance. The coils are wired so that the left front and right rear burners are on one coil; the left rear and right front are on the other. Knowing about the balance and the path of the electrical flow, finding a sparking problem can be made less complicated. This only applies to the sealed burner, non-reignition system.
Now for the service diagnostics. The customer complains that the left burner is not igniting, but the other burners are sparking. The ignition switches can be ruled out since the module is receiving the L1 voltage and a spark is produced.*Since the left front burner is linked to the right rear burner, check the spark on that burner. If the spark at the right rear is a crisp blue spark, that indicates that the 12000-14000 VDC is returning to the burner. Electricity will take the path of least resistance and would rather go to the chassis than jump the gap at the burner. With this in mind, the next thing to check is for a possible grounded igniter wire or broken igniter insulator for the left front burner. let's now take a look at the opposite affect. The right rear burner is a light blue almost white spark. This would indicate not all the D.C. voltage is returning to the burner. Possible causes could be:
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Hopefully this will help you diagnose erratic or intermittent sparking on your future service calls of this nature.
Changing an typical oven temp sensor.
Remove power first.
Due to productions changes and continuous improvements, it may be necessary to use an adaptor wire harness or wire nuts for a compatible connection.
Remove screws from inside the oven and pull towards you the inoperative sensor.
If the connection on the sensor or the wire harness is not applicable to your model, use two ceramic hi-temp wire nut connectors to splice the wires together. Strip insulation on each wire approximately 1/2" from the end. On some models, the sensor may be serviced from the front, on others the hole in the oven liner is not large enough for the wire nut/connector to pass through and must be serviced from the rear.
Important: Make sure the wire nuts/connectors are completely through the insulation and not touching the back of the oven cavity.
Once the wire nuts/connectors are properly positioned, reinstall the sensor screws removed earlier.
GE JGBP28 kitchen range
The problem is commonly caused by a weak or failed oven igniter. Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
If only one oven feature fails to work, but the surface igniters still operate, your problrem is not a gas related as both the surface and oven are fed from the same source. Each oven manifold has a separate igniter, so it is most likely a single igniter problem.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The part number for the model you have listed is WB2X9154.
If you have any qiuestions please post back and let me know. I hope this helps you.
Mar 29, 2010 | GE JGBP28 Gas Kitchen Range
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
GE XL 44 gas oven not working. I replaced the igniter for the oven, but not the one for the broiler. Also replaced the regulator valve. Still doesn't work. I didn't replace the broiler igniter as we...
most newer models of gas oven require electricity in order to work. I would check the outlet where you have your oven plugged in. Plug something else into that outlet to make sure it is live. If it is not, check the electrical panel breaker or fuse.
Oct 29, 2009 | Kitchen Ranges
Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Sep 30, 2009 | GE JGBP28 Gas Kitchen Range
I own a GE JGBP33BEH5BB and the oven doesn't get hot enough. I've changed the sensor with one from a JGBP30BEA1WH that was working fine when it was removed. (replacements for both are the same part number...
The orange glow is the igniter. Normally, the igniter turns on and begins to glow. As the igniter heats, the change in it's resistance causes it to use more electrical current (amperage). When the amperage level reaches a threshold (let's say 3.2 amps, for an example) the ovens safety gas valve will open because in knows the igniter (using that much electrical current) is hot enough to light the gas. This process usually takes under two minutes. The igniter stays on until the oven reaches the set temp, then it turns off, and the gas valve shuts off very soon after. Then the cycle repeats when the oven thermostat call for heat again after cooling down a bit.
The trouble is, as these igniters get old, they have a harder time reaching that needed amperage threshold to operate properly. You can just swap the broiler igniter with the bake igniter if you wish, as they are the same part number in your model, and the broil is generally used much less, and so should have much more life left. (of course now the broiler and the self clean will not work, until you replace the broiler igniter with a new one.) In rare cases, if you have low line voltage to the range (say 108 volts) that will also cause the same problem, or if you have a poor electrical connection, but those cases are rare, and about 99 percent of the time your problem will be fixed by replacing the oven igniter. (GE part number WB2X9154 for your model)
Sorry to get so long winded. Just replace the oven igniter.
Aug 15, 2009 | GE JGBP33 Gas Kitchen Range
GE Spectra XL44 oes not heat to desired setting
The oven sensor ( WB21X5301) is suppose to tell the oven control when to turn on and off to reach and maintain oven temp, but before you go replacing it, try to observe how long it takes from the time you turn the oven on to the time the oven ignites. Ignition should be 30 seconds to about 90 seconds. If it is taking a very long time, replace the igniter (
WB2X9154
). Ignitors get weaker over time, and this should be looked at first, as both parts are not real cheap, so you don't want to just start throwing parts at it. Here is a trick you can try: On the JGBP90 (model you posted under) the broil ignitor is the same part number as the oven ignitor, so if the broiler, which is generally used much less than the oven, is working fine you can interchange the two ignitors to see if that solves your oven temp problem without having to buy a oven temp sensor first.
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
102 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
