I suggest you go to the VZ commodore forum for that and hopefully one of the guys there will help you out if you ask politely.
Here is the link/...........
Forum VZ Holden Commodore 2004 2006
SOURCE: torque settings for holden 308
see if this site helps you.
http://www.boxwrench.net/specs_index.htm
SOURCE: I need the torque specs and sequence on a 1998 chevy 350 vortec
Vortecs are a little different that old school small blocks, grab a Haynes or Chiltons, the cross patterns and specs are simply diagramed. Vortec, as any really, start with 25# then 45# and then final torque which I believe is around 70-75# but to be sure verify with the manual. AutoZones, Murry's, Adavance auto all carry the books, Cheap insurance.
Dan
SOURCE: need cylinder head gasket torque specs.
looks like there is special sequence to reassemble and tightening, a quick note replace any bolts that have two punch marks.tighten as follows: x x x x x 10 4 2 6 8 x x x x x 7 5 1 3 9 torque all down to 15 ft lbs torque to 30 ft lbs plus 90 degrees. Good luck!
SOURCE: 2003 mazda 6 3.0 need the main bearing torque specs
I'm sending you the torque specifications for your main bearings and also your head bolts. I also sent you main bearing and cylinder head tightening sequence. I hope this will be useful
Main Bearings Torque specs. 40-43 Ft. Lbs.
Cylinder Head Torque specs. 56-60 Ft. Lbs.
Testimonial: "thank you so much! couldnt find this information anywhere, even called the local mazda dealers!"
SOURCE: brake job torque spec
Caliper mounting bracket bolts:
Front: 80 ft-lbs.
Rear: 41
Caliper mounting guide pins/bolts:
Front:
Four-cylinder models 26
V6 models 37
Rear:
All: 17
Hope this helps you.
