Question about Garden
Can't get pressure from homelite hp3127s gas pressure washer after using only 1 season. can't find manual to find problem. is there a switch i'm missing?
  • 721 Answers
No,it's probably a bad valve body or the pump itself broke. Homelite isn't the best quality machine.
Posted on Jul 15, 2009
Why is gas tank leaking?
you either have a hole in tank or a hose is bad, take some silicome and patch
Jan 04, 2016 | Garden
How come my Homelite pressure washer will not turn over?
remove spark pluug and squirt some fuel into the hole . quickly put plug in and try to start. often this will help the motor get going and might not need anything else all season.
Aug 12, 2014 | Homelite Garden
Why can't I get pressure
Bypass valve may be stuck open bypassing the pressure.
www.homelite.com/service_support
Jun 23, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Homelite ut80522d pressure washer motor reves up and down then dies
It's surging... your carburetor needs to be serviced. It's not giving the proper air fuel ratio to the engine...
BriMaxSmallEngineRepair
Gibbstown,NJ
Jul 26, 2013 | Homelite Gas Pressure Washer: 2700 psi 2.3...
Remove&replace gas tank on a homelite 2600 pressure washer mod# ut80522
if you are in the UK we have found these parts to be available from Ryobi but they dont often make the engines... identify the engine as this is who will make the fuel tank !
Jun 30, 2013 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
What is the gas oil mixture for homelite sx135 trimmer
Use 32:1 with good quality 2-cycle oil. I have Used Stihl, Homelite, Poulan and Several Other 2 Cycle Trimmers in the Yard Maintenance Service and Have Found the 32 to 1 Mixture to Extend the Life of the Engine. Always Remember to Drain the Tank and Run the Engine Until the Carbuetor is Empty for Off Season Storage.
Sep 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Need a part for Homelite model HP3127S pressure washer - 3100 PSI
I lucked out when I managed to locate a local rent it centre who sells and services Homelite equipment. I bought my pressure washer at Home Depot and when I approached staff there regarding my problem, they had no idea if there even was a local dealer who sold/serviced Homelite stuff. telephone enquiries finally led to the rental place who ordered the part for me. I was getting concerned!
Jun 19, 2009 | Garden
I did not receive a users manual with my Homelite HP3127S
Hi, I contacted Home Depot in regards to a manual for your pressure washer and was told that it was the stores responsibility to provide you with the manuals for your product. I also visited the Homelite site and there is no literature available as a part. You must register on their website to send an email with your request if you choose that option. I also had your experience in trying to locate a manual online. I believe your best recourse is to contact the manager of the store where you purchased the unit and explain that you need a manual and were advised by Home Depot customer service to attempt to resolve the issue with the store first. Let me know if you need further assistance. Hope this Fixsya!
Mar 09, 2009 | Garden
Garden Logo
452 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
