Question about Kenmore 44102 Front Load Washer
Hoover Washing Machine 550M. Cycle incomplete, clothes still wet with soap powder.
  • Glen Moore May 05, 2018
    We have a 550 which umps fine but the agitator and spin do not work. How can I determine whether the motor is faulty?
  • 92 Answers
This sounds like the motor bushes have worn,check them,they are easy to replace for about £10.00
Posted on Jul 15, 2009
  • papilon Jul 15, 2009
    this sounds like the motor bushes have worn,check them,they are easy to replace for about £10.00
My Whirlpool super capacity 2 speed 7 cycle washing machine filter is dirty because it makes marks on clothing. Any suggestions on how to fix this please. Thanks Regards George
Hi, sometimes even after cleaning the filter dirt remains in the machine. The best thing that can help solve this problem is to buy a descaling powder for washing machine (available at supermarkets or hardware store) and follow the instructions on the box or packet, this will take awhile as you will have to stop the cycle by turning the power off when the machine is full of water (with no clothing in it) and then restart the cycle, (about 2 hours). Descaling is necessary as the soap powder attaches itself on the rear of the rotating drum and cannot be seen and some dirt(streaks) will appear on the washed clothing. Hope this helps. All the best.
Apr 28, 2015 | Whirlpool Washing Machines
Zanussi aquacycle 400
all washers have water level sensors and most of them are fitted with water level via filling a tube with water the switch is activated telling the machine to turn off the water
most of the time the tube gets clogged up with soaps etc.,
clean the tube and check the operational of the switch .
Nov 24, 2017 | Washing Machines
The whashing comes out with white powder like stuff. Can I clean the drum and if so how ? is it flint that gathers some where?
Hello Sir Tommis,
I understand that you are having a problem with your washing machine. When you wash clothes they come out with a white powder like substance on them. This white powder substance is the powder laundry soap that you are using.
This is generally caused by adding to much soap and clothes to the washing machine. The soap is not getting dissolved and the clothes do not have enough room to agitate in the machine. Try to put 3/4 of the amount of clothes in the washer with the same amount of soap and see if the clothes come out with the same powder like substance on them.
The clothes that currently have the soap on them will have to be hand washed with a scrub brush in oder to get the material off of them as running them though the washer will not remove the soaked in soap.
Thank you for choosing FixYa.com
Justin
Mar 26, 2011 | Whirlpool 3.2 cu. ft. Washer
The dish washing powder does not wash out completely unless the machine is set to heavy duty only. we will often open the machine at the end of a wash cycle and see the soap powder all wet and soft but not...
Seems to be problem with spray arm pressure. Check the spray
arm jet nozzles.
Check the incoming water flow to the machine. clean the strainer fitted at the washing machine end connection.
Being in the extended warranty, take the help from
the service provider.
Aug 31, 2010 | Dishwashers
Smelly front loader washing machine. Clothes come out smelly too. How did I fix the problem???
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Washing Machines
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Our Hoover 550M has stopped draining water during it's washing cycle? Could this be the water pump? If it is where do I find it and can it be replaced?
the motor does it still adgitate the clothing ?
A maytag dealership should be able ti get you any part you need
Sep 09, 2009 | Washing Machines
My aquarius WML540G washing machine has no obvious fault apart from I am sure there must be an item of clothing trapped in the washer because my clothes smell of when something has been left wet for a long...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Smells coming from inside the drum are usually caused by a build up of soap and scum congealing on the inside of the container, (that is the container rather than the inner drum) and the worst culprit for this build up is liquid washing compounds because they do not have any bleaching agents in them and they form a kind of paste. Put the machine on a service wash, (that is a very hot wash with a good quality washing POWDER and no cloths) allow the machine to complete the cycle. This may need to be repeated once a week or month until you are happy the smell has completely gone. If possibly I would avoid liquid soap in future. But that is just my opinion.
Aug 31, 2009 | Hotpoint Washing Machines
We have a Whirlpool top loader Washing Machine in top order. I have tried various powders but always get powder "stains or scum" on items that have been washed. I use the "warm" cycle...
use what ever detregent you want try pretreating strians and heavey soiled items with shout. use recommended amount of soap and try not to overload your washer too many clothes will displace the amount of water in tub and also put strain on your washer which could cause failure
Dec 16, 2008 | Washing Machines
Kenmore 44102 Front Load Washer Logo
284 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
