Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
I have a problem with my old Fisher & Paykel Smartdrive 600 GW600B-U washing machine.It just stopped operating after the final rinse and will not drain out the water. I have taken off the inspection plate and checked the pump and there doesn't seem to be any wetness around the main seal area where the pump connects the tub, however there is a slow drip off the pump fan at the bottom.Could this leak be because of a worn pump shaft? and is this repairable.thanks
  • trevorj59 Jul 15, 2009
    my problem is NOT a refrigerator! Its a GW600B-U smartdrive 600 Fisher & Paykel washing machine
Spiz
SOURCE: Our Fisher and Paykel Pride
Sounds like your pump is blocked. **UNPLUG the machine**. lift or drag the machine to a spot where you can let the water dump out. The water comes out fast and makes a big mess. Tilt the machine back. On the front-right underside of the machine you will see the pump with the fan hanging down. Unplug the white plug and the earth cable from the back of the pump. You might notice that there is a white plastic clip that you can move to the side. Hold the clip out and twist the pump clockwise. At this point the pump will drop out and water will go everywhere. Try and take the pump out kinda fast so that the coil does not get too wet while the water is dropping out. you might find a blockage (coil, hair clip, underwire etc) sticking out from where the pump impeller sits. Pull out your blockage and check that the pump spins freely when you spin it by hand. If it does not spin freely you need a new pump.
Now, after you unblock your pump, you can put it back together the same way you took it off. Make sure the white plug is not wet before plugging it into the pump and make sure the pump coil is dry too! use a blowdryer to dry for a minute if unsure. When twisting the pump back in, the wires should be at the back of the machine and the earth cable is kinda close to the rotor (motor). Make sure the pump is sitting flat so the seal works too. That clip should click lock back into place to hold the pump from turning. The washer will not spin until all the water is out in case you are wondering. Hope this helps!
Posted on Aug 02, 2008
Krazytech
  • 725 Answers
SOURCE: my fisher and paykel smartdrive
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Posted on Dec 15, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
garing
  • 998 Answers
SOURCE: FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Posted on Aug 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 07, 2009
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel washing machine excellence 6.5 smartdrive 8
see this possible causes: God bless you
see the diagrams
Lid switch
test for defective or open
Motor coupler
replace coupler motor for defective
Belts
worn belt
Clutch
wears replacement
Drive motor
one winding burn , run with one winding in one direction and another with the other winding.
Drive pulleys
frozen pulley, worn.
Transmission
broken gear+ shifter defective
Agitator
worn agitator replace
5_16_2012_7_59_29_pm.gif5_16_2012_7_59_43_pm.gif5_16_2012_7_59_54_pm.gif5_16_2012_8_00_26_pm.gif
May 16, 2012 | Fisher and Paykel Washing Machines
Washing Machine F&P MW511. Washed, then rinsed using the fabric softener, partially spun then stopped. Will not turn on at all now (no power)
Hmmmmm - I think you may actually have a faulty controller module - without a working module it generally means no power on etc for Smartdrive washers..
Jun 26, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Frigidaire smart Drive 600 washing machine
LOL you have a 600 throw it our buy a new is the best option. :)
Sep 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Aug 30, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
85 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
