Question about Dishwashers
My Jenn-Air dishwasher has sprung a door leak! :-(
My Jenn-Air dishwasher (model DW86OUQW) has now started leaking from the bottom-right of the door -- what kind of gasket is needed to correct this and is the gasket still available on such an old appliance? Thank you.
  • 297 Answers
It's just a door gasket,you might still find it a appliance repair place.
Posted on Jul 15, 2009
Leaking at the bottom of the door and unsure where plastic door seal goes.
This dishwasher will leak if there is to much water in the unit.
I have the same dishwasher with a different problem.
Mine won't circulate the water. I have not use it for a while and some water will back feed from the sink and fill the dishwasher, so if I don't check for that problem once in a while I see it start to leak.
It never has done that when the unit was working....
Aug 28, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn Aire dishwasher DW861upq leaks
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 06, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
My admiral is leaking at the bottom of the door. I have checked & cleaned all around the seals that made it worse.
The most common reason for leaks is a failed/cracked gasket. Replacing it is actually not as hard as it appears.
The second reason for leaking is damaged/bent (sprung) hinges that, when the door is closed/latched do not tightly seal the door against the gasket.
Please report what you find, OK?
Aug 05, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
Leaking door
Step one is to carefully inspect the gasket that is mounted on the dishwasher (not the door) and search for damage.
If the gasket has not failed, look carefully as the door is closed. If the door/hinges have been damaged (sprung) your dishwasher can not close completely.
Report back here what you found and if that does not solve the problem there are further steps to take,=. OK?
Aug 04, 2009 | LG LDF6810ST Stainless Steel Built-in...
Jenn Air dishwasher leaking
the emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Jul 19, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Jenn-Air dishwasher: error code C2 and C1
This is not a JDB6510 Model. Check the inside label when you open the door.
Sep 09, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
My kenmore built in dishwasher is leaking out the front
change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
Feb 02, 2008 | Dishwashers
Dishwashers Logo
228 people viewed this question
Top Dishwashers Experts
Owen Barnes
