Question about Volkswagen Golf Vw Diecast Model
All the coolant leaks out of the front of the engine when i add coolant on my VW jetta GLS VR6.. how much would it cost to fix this?
  • 130 Answers
TRY U SOME SUPER GLUE,,LOL
Posted on Jul 15, 2009
Ignition coil firing order for 2000 VW Jetta VR6
Jetta GL & Jetta GLS (two versions with 2.0 l and 115 CV engine)
2000 Volkswagen 2.0 liter SOHC L4 (AEG)
Jetta GLS VR6 y Jetta GLX VR6 (2.8 l VR6 and 200 CV engine)
2000 Volkswagen 2.8 liter DOHC V-6 (ATQ)
Hope helps.
Mar 22, 2011 | Volkswagen Jetta Cars & Trucks
I bought a 2004 VW Jetta GLS 1.8L Turbo earlier today. It has a clean carfax and recent (within a week) negative dealer diagnostics...it overheated. Well...it overheated within 2 minutes of hard...
Hold the dealer accountable, for starters! It could be the thermostat, a coolant leak, a severe engine problem, who knows? You shouldn't have to concern yourself with diagnosing and fixing a car you bought yesterday, unless you bought it as-is.
Feb 18, 2011 | 2004 Volkswagen Jetta
How to tell if your 2000 Jetta gls vr6 need struts? My car squeeks when I driving and If I push down on the hood.
After ten years your are sure to need a new suspension. The way you cantell the shocks are gone is you'll see signs of fluid leaking from the inside of the top onto the outsides of the inner bottom. A couple of jacks and the right wrenches will be pretty easy for even a novice mechanic. Two to four hours your done, it will also increarse the cars hoursepower and preformance.
Jul 15, 2010 | 2000 Volkswagen Jetta TDI
I have a 1997 vw jetta with the vr6 in it, and the heater core was recently replaced because of a leak, but now, that is fixed, but the car is overheating and shuts itself down after a few minutes of...
Ouch, don't let it overheat it'll cost you a new head gasket. You probably just don't have enough coolant. They probably filled it up and didn't run it to drain the reseroir and refill it. Check the coolant level, make sure it is full. Failing that, the thermostat might be stuck, the rad might be clogged if it's old, the new heater core might be the wrong one a too restrictive. I can't rememebr if my old VR6 had a ad cap but if it does take the coolant cover off the rad, start the car with it off... don't worry it's won't spit of anything, look down to see if the fluid is moving, if it is then you have circulation. Dont' run it like this for too too long as it will begine to Overflow. My bet is the coolant level bro. Cheers.
Apr 03, 2010 | 1997 Volkswagen Jetta
Looking for a website that will help identify exterior engine par
I will suggest getting a Chilton manual. It is a book. You can find the manual on-line at www.autozone.com
I would still recommend getting your own copy, so you can write on it and get it greasy.
I have a 2001 VW passat V6 and do all my own work. Please, post your problems as clear as you can, I will do my best to help.
How does the car run otherwise?
The coolant, is it coming from the same place?
The oil leak, is it near a pulley?
Feb 01, 2010 | 1993 Volkswagen Jetta
Need instructions on how to replace ignition switch? on a 98 vw jetta gls
ARE WE TALIKING ABOUT THE KEY CYLINDER OR THE ELECTRICAL SWITCH?
Oct 01, 2009 | 1998 Volkswagen Jetta
1996 vw vr6 engine coolant leak in front of engine
A blown head gasket doesn't necessarily mean there is water in the oil. Check for bubbles coming into the coolant tank. Take car for a short drive to build up coolant pressure and you should be able to see where it is leaking from a bit easier. It is possibly coming from a heater pipe or core plug.
Aug 09, 2009 | 1996 Volkswagen Jetta
1996 vw jetta vr6 keeps overheating,
Get another boyfriend! "Just kidding"! ok, this is what I mean about "leaving it to the experts". #1 Make sure there is enough coolant, Check for leaks. Install a coolant pressure tester and check for leaks. Fix whats leaking. #2 Make sure coolant fans are coming on, and specifically at 220 degrees. If not, check fuses. Jump the coolant fan to make sure it comes on. if it does, then you may have a bad relay, make sure relay is commanded on. At this point , you may need a wire schematic for the coolant fans and related parts.
Jul 23, 2009 | 1996 Volkswagen Jetta
Finding Thermostat on 98 Jetta GLS
Its to the right of the water pump towards the bottom of the engine.. Follow your lower radiator hose. Make sure to get some G12 coolant from VW before you do it. If you mix the coolants they turn into a gel that will cause you to overheat.
Jan 05, 2009 | 1998 Volkswagen Jetta
How to replace a coolant temp sensor on a 2001 vw jetta 2.0
Yes it is that easy. It should be a 4 pin connector located on the transmission side of the engine head in a plastic flange. Best is to wait for the engine to be cold. Unscew the radiator cap to relieve pressure but screw it right back on. On the 2.0L engines when you unclip the coolant sensor little or not coolant loss will happen if you do this. Just unplug it, pull out the clip, pull out the sensor, and the seal which sometimes stays stuck. Install the new sensor with a new seal lubricated with some coolant, make sure it's well seated and reinstall the clip. The sensor is well seated if the clip fits right over the top, just make sure both sides clipped into position. Replug it fill the coolant with VW original coolant mixed 50-50 with water if needed and done. If you have a fault you might need a scanner to erase the check engine or fault in the cluster.
What's the reason for changing it? Eratic temperature readings?
Nov 28, 2008 | 1999 Volkswagen New Jetta
Volkswagen Golf Vw Diecast Model Logo
309 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Bogdan Odwazny
Bogdan Odwazny
JonSnell Electronic
JonSnell Electronic
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
