Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I have clean the printheads calibrated printer and the black prints very light . Ive tried the demo printout on the unit it prints very light .Ive installed a new ink cartridge still no difference. I have read the trouble shooting guide and they reccomend a new printhead after trying cleaning printheads.Where do I get a new printhead.
    Scholar:
  • 119 Answers
Http://www.kodak.com/go/itg
Given your situation, you will follow the troubleshooting through the steps and it will provide instructions on what you need to do to get a replacement printhead for your light prints.
Posted on Jul 14, 2009
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
It will not print the black ink
Have you clean the printhead and reseating the ink cartridges?
heres the you need to do
-Reseat both ink cartridges
-Calibrate the printhead (Press menu button and look for calibrate printer to do it)
-Clean printhead (press menu then look for clean printhead choose deepclean)
-Press and hold Photo and copy botton at the same time to print your DEMO PAGE!
-If the black is absent it means the nozzles of the printhead is clogged you need to call kodak for printhead replacement Toll Free 1 800 421 6699. GudlucK
Nov 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 prints light or not at all color does better
to resolve the problem try to clean the printhead first, to clean the printhead just press on the menu button, select clean printhead, select deep clean.
After you clean the printhead try to re-calibrate the printhead, just go back to the menu the select calibrate printer then select print calibration page. Once you have the calibration sheet, place it on top of the scanner make sure that the blue arrow on the printout is pointing on the yellow arrow located on the top corner of the scanner glass then press on the start button to scan the calibration page. Once the calibration is complete try to make a test print, just go back to the menu then select print demosheet then press ok. If this will not correct the problem you need to call their technical support hotline
Aug 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Our 5300 won't print black text yet there is more black ink than colour.
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Not printing
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
Is the Demo printout giving the same result?
If so, you may need to replace the printhead. This is a very common problem with this model. Call Kodak, they will send you a new print head, if the unit is under warranty.
Live phone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight Eastern time, 7 days a week.
The expected wait time for phone support is 15 minutes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 07, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My Kodak 5100 printer has been great. Even though
Thanks, Joe
Mar 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5500 Printer Pa[per jam
Verify that the ink cartridges are intact and securely inserted into the printhead, then make the same print.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If this will not correct the issue, try to follow these steps
  2. Press Menu.
  3. Select Clean Printhead, then press OK.
  4. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  5. When the On/Off light glows a steady green, select Print Demo Sheet, then pressStart.
If these steps will not correct the issue on the printout., you need to call Kodak technical support ( 1 800 421 6699) possible the printhead is defective and it needs to be replaced
Dec 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer problem
Most likely it is your printhead, the printhead becomes clogged when the printer is not used to print for a moderate amount of time. There are 2,000 some nozzles in the printhead and it does happen. The ink drys up and clogs nozzles. You can try to perform a printhead clean from the main menu, deep clean preferred. After that try to calibrate. Then print a demo page if there is no improvment you most likely need a new printhead. Also doing a regular print head clean, once a week, may prevent this in the future.
Sep 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
120 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
