RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
o.k test the a) water supply cold. read your instr. manual some model during the cycles coming cold water other hot water, read for is acting abnormally. b) TESt the timer see the diagram> tight any wires connector loose or corrosion, or dirty. see the w.diagram how the timer control any function of the washer. God bless you
Possible failure of the main program controller unit as it fails to contact at times and resets .
Since you mentioned that it is erratic the program is not executed to contact to the job of the cycle and so the drain pump/valve is stopped mid way.
Erratic behaviour in wash programmes can often be due to clogging of the path between the tub and the pressure sensor which senses the water level in the tub. Clogging can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme.
We had the same problem. We unblocked the filter (found a hair grip, a belt buckle and a sock) and with luck it will be fine now. To unblock the filter pull down the little white round flap on the front of the machine and unscrew the filter. Beware though water may pour out when you unscrew the filter.
