Question about Intel Motherboard
Gigabyte ga-8skml i have a problem with my gigabyte ga-8skml motherboard it cannot detect any hard drive or cdrom drive, pls help me with my board, tanx...
  • kobie13 Nov 18, 2007
    i use different ide cables for the cdrom and harddrive, that harddrive and cdrom is working/can be detected on my other motherboard but in my gigabyte motherboard that harddrive and cdrom can't be detected
  • 87 Answers
Well their could b 2 problemz as i know
1. IDE cables
2. Jumpers may b not properly configured
so u just let me know that r u connecting ur hard disk n cd rom on one cable or two different cables? then i myt suggest a solution for u! n do check ur cables n jumpers setting that r they configured correctly or not?
Posted on Nov 17, 2007
Gigabyte GA-8I915ME-G Motherboard + 1 TB WD HDD
Insert the SATA and Power connector, enter the BIOS and ensure that SATA 2.0 controller is enabled.
Now boot into Windows and click control panel.
Double click Administrative tools and double click Computer Management.
Left on screen: Select Disk Management under the heading, storage.
Here is where the hard drive should be detected. If not present click action, followed by refresh.
Now select your new drive and format it using NTFS.
Take care!
Jun 07, 2012 | Gigabyte GA-8I915ME-G Motherboard
Gigabyte GA-6OMM7E (GA-60MM7E) Motherboard have not display, please solution to me.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 07, 2011 | Gigabyte GA-6OMM7E (GA-60MM7E) Motherboard
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables...
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Oct 11, 2010 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-MA78GM-US2H - unknowingly i spent 2000 INR on DDR 2 ram. can this board support DDR 2 RAM ?? pls help
according to the site:
DDR2 1066 or above speed is only supported by 1 dimm per channel.
Here is the link for the support of your motherboard.
Dec 14, 2009 | Gigabyte GA-MA78GM-US2H Motherboard
Which is the maximum capacity of hard disk for this board? Gigabyte GA-7IXE4
As such you can alway increase limit by any means.
But the limit of this board it 2TB maximum on IDE.
But if you need more then attach USb drive or SCSI for the same
May 15, 2009 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Intel Motherboard Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
