Question about D-Link Xtreme N DIR-655 Wireless Router
Cannot get computer to connect to the router via cable. Says acquiring ip then fails.
    Scholar:
  • 62 Answers
Are there other computers that are successfully obtaining IP address/connecting to the internet through the router? Try the basics first --use another ethernet cable (a known-working one if possible), use another port on the router, power off and on the router.
Posted on Jul 15, 2009
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
May 18, 2011 | Computers & Internet
I have connected my DI-104 Router to my Motorola Surfboard modem and have two LAN cables to two other computers. However, neither computers recognize the connection. I have my main computer connected via...
Turn the router off.
Use an Ethernet cable to connect one computer to one of the 4 'LAN' ports on the computer.
Turn the router on.
Click Start
Click Run
Type CMD
Press ENTER
Enter IPCONFIG /RENEW
Press ENTER
Look for lines of output like:
IP Address. . . . . . . . . . . . : 192.168.40.150
Default Gateway . . . . . . . . . : 192.168.40.1
Open Internet Explorer.
Enter: http://192.168.40.1 (if that's the IP-address on your computer for the 'Default Gateway').
You should see a D-LINK "login" web-page.
Try an ID of 'admin' and a 'blank" password.
Once logged-in, you can check the router-settings, and then "configure" it.
Jul 17, 2010 | D-Link Express EtherNetwork DI-604 Router
Fails to connect
try to reset by pushing the button in the back then run the setup wizard by accessing your routers page via the ip address if you do not know your routers ip address plug it into your computer with an ethernet cable open up your command prompt and type in ipconfig then enter and look for your default gateway
Mar 28, 2010 | D-Link DIR-300 Wireless Router
Acquiring network address
Sometimes you have to change your computer's settings or the routers settings to know what type of encryption its looking for otherwise it will just stay on acquiring.
Sep 19, 2009 | Linksys WRH54G Wireless Router
Failed to get boot parameters via DHCP
You didn't provide any information about your network which is ALWAYS required to provide any type of help, not to mention a solution.
"Failed to get boot parameters via DHCP, xxx seconds until reboot" simply means that the computer isn't getting an IP address from your router. Setting up your router is another entirely separate topic.
This is pretty simple though, one of three things is happening:
1. Your router is not properly configured to provide DHCP to the phone.
2. Your network cable is bad.
3. Your phone is bad (most likely the RJ45 port since the phone seems to work otherwise).
You can check for bad ports or cables by checking the port status within the router. If the port is lit up, most likely the cable and phone port are fine. This is not 100% though, replacing the cable should always be a consideration even with a lit port.
Apr 10, 2009 | Polycom SoundPoint IP 501 IP Phone
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Hard Wired Port Problem
please dont assign any manual addresses in ur computer..let it be automatic...
u said that u connected the computer to Ethernet ports in the router...
check whether the light are lit in the router corresponding to that particular port..
check the ip address to that particular computer(hard wired to the router)
ip address should be 192.168.1.100 or 101 or 102..if the ip addres comes in this range means its working good...
if ther is no ip means please follow this steps...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
May 31, 2008 | Linksys Wireless-G WRT54GS Router...
Can't connect via cable, but wireless works fine
seems you are using winXP-P. Your firewall might be blocking it. Or your virusscan program might be blocking it. Come back after disabling these features and trying again.
Oct 09, 2007 | MSI RG54G2 Router (MS-6848-002)
D-Link Xtreme N  DIR-655 Wireless Router Logo
109 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
