Question about E Sky Flight Simulator Training Kit
I have an e-Sky 0905A. The problem I am having is that I am unable to calibrate the transmitter. When the left hand stick in the upward position the calibration shows the full throttle is in a downward position and the right rudder stick will tip the helicopter over when excelerated. Please advise. Thank you.
  • 3,741 Answers
The controller just plugs into your PC USB port. Load the software from the CD and off you go! Be sure to go to the Controller menu and calibrate the controller before you try to fly. You will have to reverse several of the controls and re-assign the throttle control to the proper control stick. software is missing settings.set all the settings and try in each setting. keep updated.thanks.
Posted on Jul 14, 2009
Hello. How can I recalibrate the sticks on Turnigy 6X?
Here ya go!
turnigy 6xs stuck through stick help
and
Turnigy 6XS does not work properly
and
Turnigy 9XR How To Do Stick Calibration
Then there was this burred text:
"Look up "Turnigy 6XS Thro Stick" on YouTube to see why. The transmitter won't boot into the main menu unless the throttle stick is at 0, which is a nice safety feature. However, if you calibrate the sticks with the throttle any lower than dead-center you can end up calibrating the 0 position lower than the throttle stick will go."
Turnigy 6XS FHSS 2 4ghz Computer Transmitter 6 Model Memory Inc 7 Ch...
*** HOW ABOUT A THUMBS -UP if this helped you!
Jan 06, 2018 | The Computers & Internet
I hsve a 2008 saturn sky base 2.4L. The dealer says I need a new body control module. My question does the new BCM require reprogramming? If it doesn't then I will replace myself. Thanks
Body Control Module (BCM) Replacement and Reprogramming
If the BCM is replaced or requires reprogramming, the following procedures must be performed in the specified order:
BCM Setup -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup BCM and follow the on-screen instructions, making sure to select the proper RPOs and input the VIN correctly.
BPP Sensor Calibration--Refer to Brake Pedal Position Sensor Calibration
Program Key Fobs--Refer to Transmitter Programming
Setup SDM Part Number in BCM -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup SDM Part Number in BCM and follow the on-screen instructions.
Dec 28, 2016 | Saturn Cars & Trucks
My v913 does not respond to left turns. mode 2
i think it has something to do with the signal to heli from transmitter
Jan 15, 2014 | WL Toys WL V913 Sky Dancer 4CH FP...
Wii Fit Rhythm Boxing: So right hand holds wiimote, left hand holds nunchuk. Right hand punches register every time. Left hand puncheshardly register ever. I don't think it's my coordination; I'm giving it...
I had the same problem until I realized I was holding the nunchuk "backward." Or rather, upside down. With your palm facing down toward the floor, the nunchuk should curve upward, and the center button that sticks up should be facing to where your thumb can rest on it. I had mine the other way, with my thumb on the "trigger" and nothing was registering. So, play with the positioning of the nunchuk in your hand.
Dec 26, 2010 | Nintendo Wii Fit for Wii
When I try to play a game (Call Of Duty WaW), it won't let me look up, and makes me spin around. I thought it maybe was the Look Inversion in the options, so I changed it, but then it only let me look to...
If you spin around that means the right stick is being pressed in a direction without you even touching it because of loss of calibration. There are some calibration utilities online but for the start you can let Windows calibrate your gamepad.
Open control panel -> classic view (on the left) -> Game Controllers -> Select your controller -> Properties -> Settings tab -> Select Calibration and follow the instructions. If during calibration you see that the right and/or left stick is being pressed in a direction, it is a hardware issue. In such cases replacing the controller is a better option. If it is still under warranty you can get it replaced. If you bought it from Game stop they do normally accept returns within a month or so.
There is one thing you can that sometimes works: Press the right stick towards right and turn it fast in a circle all the way through clockwise. Repeat it 3-4 times and then do it anti clockwise. It works for me each time my controller acts like that, I dont know how but it doesnt matter. Hope it works.
Apr 04, 2010 | Microsoft Xbox 360 Controller
I have just purchased a Esky 0905A simulator but
To download the FMS flight sim go to this sitehttp://n.ethz.ch/student/mmoeller/fms/index_e.html
But you will need to also add this file to your computer if you are using Vista. d3drm.dll go to http://www.driverskit.net/dll/get/494.html to download the file. Then put it in your C:\Windows\System32 folder on your computer. It wont work until you do this. Good luck.
Jul 13, 2009 | E Sky Flight Simulator Training Kit
We dont know what way the nut undos on the back weel
I don't know which nut you are talking about but, guessing you are talking about the lug nut on the tire.....
if you are looking at the rear tire on the driver's side, your right hand towards the back of the car....the left hand towards the front of the car, left hand at the 9 o'clock position and right hand at the 3 o'clock position, you want to push down with your left hand and pull upwards with your right hand.
Same motion if you are on the passenger side.....except your right hand would be towards the front of the car and your left hand would be towards the trunk.
Mar 29, 2009 | 2006 Ford Laser
ESky Simulator FMS (0905A) doesn't work
When I re-started my computer and calibrated the simulator again, it started to work. As simple as that.
Thanks for your help.
Zlatko
Feb 12, 2009 | E Sky Flight Simulator Training Kit
Esky 0404 would not work with usb
Disconnect from the internet. Then try turning off you anti virus software and try again. If it works you can change your exceptions in the antivirus software.
Jan 09, 2009 | E Sky Flight Simulator Training Kit
E Sky Flight Simulator Training Kit Logo
559 people viewed this question
Top E Sky Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an E Sky Toy Expert? Answer questions, earn points and help others
