Question about Nintendo Wii Console
Error messages when updating Wii with my wireless connection
Error message 61212 when updating Wii to channels on Wii
  • 51 Answers
It sounds like your Wii is not getting a strong signal. Go to your internet settings and perform a connection test and check your signal.
Posted on Jul 28, 2009
    Problem Solver:
  • 14 Answers
Maby the place youre wii is put. I had to put my wii in a higher place.
Update error message #32004
To solve this error :
Ensure you are using a broadband or high speed internet connection such as cable, DSL, or fiber optics. Slower connections, such as dial up, may cause issues with the Wii or may not work properly.
Ensure there is no interfering devices by shutting off microwaves, cordless phones, wireless keyboards, and wireless mice.
Disable your firewall settings, as it may be causing a connection problem.
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
If you are attempting to connect your Wii console online using the Nintendo Wireless (Wi-Fi) USB Connector and you receive this error.
Aug 23, 2011 | Nintendo Wii Console
Wii says needs update in order to connect with Wii Store which would allow me to download NetFlix Ap. It is connected to the net but I keep getting error message that says update could not go through. It...
Hi there!
There are two ways to connect your Wii to the internet; you can connect to your wireless network (if you have a wireless modem set up in your house), or you can connect using a wired connection directly to your modem.
If using a wired connection, you will need to purchase a Wii LAN adapter and connect that from your WII into your wired router.
Once you have figured out what connection type you will use (and if using a wired connection, purchased and connected your Wii LAN adapter) you will need to take the following steps:
FOR WIRELESS CONNECTION:
  • Turn on your Wii and click on the "Wii" button on the bottom left of the screen
  • Click on "Wii Settings"
  • Click on the arrow on the right side of the screen and select "Internet"
  • Select "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click on "Wireless Connection" and then "Search for an Access Point"
  • Select "OK" and the Wii will display all the wireless networks it finds.
  • Select the wireless network that is yours.
  • If it asks you to enter a password or key, then your wireless connection is password protected and you will need to enter the password that was setup to allow access to your network.
  • Select "OK," "Save Settings," and then "Yes."
  • Your Wii will test the connection and you should get a message saying connection was successful.
FOR WIRED CONNECTIONS:
  • Connect your Wii to the Wii LAN adapter and connect that to your modem or broadband adapter. Please not that you will need to unplug your modem for a few minutes to reset the connection and you will also need to unplug the connection to your computer when you want to connect your Wii to the internet.
  • Turn on your Wii and select the Wii icon on the bottom left
  • Click the arrow on the right side of the screen and select "Internet"
  • Click "Connection Settings"
  • Click "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click "Wired Connection"
  • Click "Ok"
  • Your Wii will now do a connection test
  • You should see a message saying the test was successful
Hope this helps!
Jul 06, 2011 | Nintendo Wii Console
Trying to connect wii to wireless internet and recieving a error message code of 51331
Hey there. Hope this helps.
51331: this error is caused by the Wii being unable to connect to the access point
So what you need to do:
If your router is using WEP encryption
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
If your router is using WPA encryption, the Wii is compatible with :
  • WPA - PSK(TKIP)
  • WPA - PSK(AES)
  • WPA2 - PSK(AES)
If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings.
May 22, 2011 | Nintendo Wii Console
Error code 32002 when trying to update
Try changing the channel on your wireless router to channel 1 or channel 11 which can increase download speeds. The error means your wii encountered a connection error whilst downloading the update from nintendo, this could be your internet connection, or too many people on nintendo servers
Mar 19, 2011 | Nintendo Wii Console
Hello.... trying to connect to Wii shop channel and i'm getting error code 051030... unable to connect to server... I originally had my server provider hook up everything ... and I was able to access Wii...
If you think it's a connection problem, go check out the Connection Settings in the Wii settings menu. Run a connection test, and make sure your settings are correct. Re-enter your WEP key and such if you're using things like that.
Error Code: 051030
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
* If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
o If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
o If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
* Check for interference that may be preventing a successful connection. Click here for tips.
* Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
* Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
1. Login to your router's settings (click here and select your router, if available, for information).
2. Look for the section for SSID (typically in the "wireless settings" area).
3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
* Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
* The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
* Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
* If the problem persists, try our general troubleshooting steps.
Wireless Channel
If there are other wireless devices in the area, they can interfere with the signal so much that the Wii console will not be able to connect to the router. Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1, and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab. =D
Mar 15, 2011 | Computers & Internet
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
Feb 28, 2011 | Nintendo Wii Console
Wii error code 32022
Knicked this from a forum site:
"I don't know if it's coincidence but I was having the same problem. When the error message came up it said that I should check my internet settings. So I went to wii options-->wii settings-->wii system settings 2-->internet-->agreement/contact.
I re-accepted the terms and conditions for the shopping channel and then went to try the update again. It worked. If you are still experiencing problems with the update you might want to try this."
The fault is with the update not the console so don't worry too much
Jan 24, 2010 | Nintendo Wii Console
Cant connect my wii get error 51030
This might be handy: http://www.nhotspot.net/wii-error-code-51030/ and http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Verify that the proper Connection File (1, 2, or 3) is selected in the Wii System Settings.
If you have multiple connection files setup, and you have recently received a system update, it is possible that the update has caused the Wii console to select a different Connection File. Click here for step-by-step instructions on viewing your connection settings.
Make sure that your network's name (SSID) matches exactly to what you have entered in the Wii console's settings.
Log in to your router using the default IP (consult the router's owner's manual for assistance).
After you find the SSID (network name), verify in the Internet Settings of your Wii console that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
Oct 19, 2009 | Nintendo Wii Console
My wii nintendo channel keep coming up as error code 261412 every time i load it. This code comes up after you send the info
Error codes within that range usually refer to a communication problem with Nintendo's network. :1: Make sure your Wii has an internet connection, you can test this using the shopping channel, internet channel or by sending a Wii-mail to a freand. ::2: Go in to the setting panel and run a firmware (system) update to ensure you have the latest firmware. :::3: Try again at a less busy time of day, 15:00 on a week day is usually quiet. If you still have problems after a firmware (system) update message back. Nick. :)
Nov 06, 2008 | Computers & Internet
It wont download mario kart
Hi. This code meens that you wiishop channel is having troubles connecting properly to nintendo servers.
Since you´ve got this error code your using the wireless connection, right. Try moving the wii closer to you access poit (ADSL modem, router etc.) That might help..
Oct 04, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
466 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
