Question about Sunbeam 4214 Iron
Steam doesnt work
Recently the steam quit working on my iron, actually once in a great while it will steam but only for a few seconds then quits again. Is there any suggestions to fixing it?
  • panapana Nov 20, 2007
    Thank You sooooo much that was very helpful and I will work on that. I appreciate it.
    Problem Solver:
  • 14 Answers
A mineral buildup from your water may be blocking the holes in the soleplate of your iron. Before you do anything, read the instruction booklet for your appliance or call the manufacturer. The old remedy of using vinegar to unclog an iron is no longer recommended for many models. Some manufacturers suggest alternating tap and distilled water in the steam compartment to avoid a mineral buildup; others recommend using a specialized cleaning product (available at fabric and grocery stores) to clean the soleplate.
Posted on Nov 17, 2007
  • Steven Perun
    Steven Perun Nov 17, 2007
    Here are some tips I uncovered doing a web search:
    1. If the substance stuck on the
      bottom of the iron is waxy, you should turn the iron onto its highest
      setting and run it across newspaper until the residue disappears.
    2. If
      the substance is oily, then just wet a rag with ammonia. Next, just
      rinse the iron off with some water and the gunk should be gone.
    3. Vinegar
      works as a cleaning agent for many irons. Pour some on a clean cloth,
      and wipe the surface of an iron throughly. If that doesn't work,
      combine vinegar with baking soda. With a soft cloth, scrub the surface
      of the iron.
    4. You
      can get rid of any build-up in the vents of the iron by taking a cotton
      swab or a pipe cleaner and gently sweeping the residue out of the area.
      If you attempt to use something of a harsher nature, like a tool or a
      knife, you could scratch the base of the iron, causing future problems.
    5. To
      clean the reservoir of your iron, pour a solution that is one part
      vinegar to one part water in. Turn the iron on. Allow it to steam for
      about four minutes. Drain the iron for an hour, and be sure to repeat
      the process with clean water before you iron any clothing items.
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Tefal steam generater pro express turbo
Most of the time the electro mechanism release the steam still open and not able to returning in closing position.Try to cclick quite few time to excite the mechanism and some times work.Also can be the micro switch defective.
Good Luck
Jun 09, 2008 | Irons
Bad iron
I would look for the simlpest type of iron.
One without electronics built in and a manual setting.
When combining steam and heat, sensitive electronics don't do well.
I have seen reviews about your iron and many are bad ones.
Jan 05, 2008 | Black & Decker AS150 Iron
Shot of Steam
take it down and clean, it is clogged up.good luck.
Nov 25, 2006 | Rowenta Power Duo Iron
Sunbeam 4214 Iron Logo
296 people viewed this question
Top Sunbeam Irons Experts
Tony
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
