Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
Hd100 wont ignite
When i turn unit on can here clicking but wont ignite at all i can smell the unburned propane coming out of blower
  • 139 Answers
Since heater is calling for heat,i suspect ignitor is faulty.it could just be dirty.remove it clean with fine steel wool.
Posted on Aug 11, 2009
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
I have a rlp100 heater that works well but now has an annoying smell. It also burns your eyes some. It is 3 years old and hasn,t been used much. What can I do to get rid of the smell?
The smell is unburned propane and the burning of the eyes is caused by carbon monoxide. My heater (RLP100) does the same and I was able to measure the carbon monoxide at 95 ppm (deadly). I have yet to figure out what exactly is happening. Tried a new regulator/hose from a new unit - no help. Also pulled apart the burner nozzle and cleaned the holes - helped a bit. Next step is the valve.
Dec 18, 2010 | Reddy Heater RLP100 Portable Forced Air...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
H400 Lights, but turns off after 2 seconds
There may be a pressure regulator internal to the unit that has failed. For safety, most gas appliances monitor the output of the internal regulator; in a situation where the gas pressure is unstable, if the main burner does not ignite within a finite period, they will shut down to avoid a buildup of unburned gases that could pop your windows out (or worse) if the ignitor keeps trying.
Jun 17, 2009 | Hayward H Series Pool & Spa Heater 400k...
Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Jan 11, 2009 | Century Tool 2320I Heater
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
264 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
