Question about Fire Magic FireMagic (LP) 14-S000C-0 Grill
13 year old firemagic -- rusted burners and grid. can i get replacements?
Had same problem with 5 year old Firemagic Magnum. I tried to use a wire brush and found it too hard.
I took out the burners from the grill and soaked the burners in vinegar for 4 hours. Used a nail to unplug the holes. Rinsed in water.
Just like new. Nice blue flames. Saved $190 per burner (my grill has 3 burners).
Used the money saved to buy bunch of steaks.
Posted on Dec 21, 2011
  • 57 Answers
Yes you can look up Atlanta Grill Services on the internet call them they can get the parts for you.
Posted on Aug 27, 2009
Your Question Preview Fire Magic A790i Logo Problem with A790i Firemagic a790i flames pop and knobs get hot Posted by Author imageGuest on 3/24/2013 Details not getting good pressure to all 3 b
It sounds as if the burners may not be properly seated on the valves. Instead of all of the gas flowing into the burners, some of the gas is escaping behind the front panel and creating a fire behind the front panel which would heat the valve shafts and melt the knob inserts. This call also be caused by partially blocked burner venturi and valve orifices.
Check to make sure the end of each valve is completely inside of each burner.
Mar 24, 2013 | Fire Magic A790i
Firemagic ECHELON E660i - flames shoot out around the orfice heat stressing the front panel, making controll knobs too hot to touch and allowing flames to shoot up onto the lid, grill is 20 months old. ...
Has this been happening since new or did it just start?
Either way, you need to check the burners for proper placement over the burner orifices. Are they fitted snugly? Are they running perfectly parallel to each other and resting properly on the back inner cabinet of the grill, in the burner holders.. Also, make sure that the orifices are screwed in tight and are not clogged. Check the burners for clogs and if found clean out the burners, by gently tapping them on a firm surface.After doing that, turn the up so the orfiice end is down and see what falls out of the burner(s). If the burners or orifices were clogged or the orifices not tight, it may be backfiring into the control panel. This can also indicate a gas pressure problem.
If you can remove the front control panel (remove the burner knobs, first) you can access the gas fittings to each burner's control knob and it's gas fittings. Without lighting the grill, turn each burner ON and check for leaks with soapy water at all the connections. Then turn it off and check for leaks again.
If you found any leaks, check each fitting to make sure it's not cross threaded and re-tighten.
If none of the above solves the problem, contact the Fire Magic Dealer you purchased it from or the R H Peterson Company (they make the Firemagic Grills), as it may be a manufacturer's defect. They have an excellent warranty program. For a warranty claim, you will need your Proof of Purchase.
Hope this helps to get you back grillng>
Feb 21, 2011 | Fire Magic FireMagic Grill
I have a very old Tappan electric cooktop 13-3087-10 with solid burners. One burner has a round button in the middle that has become rusted "pushed in". What is the purpose of the button?
This is the temperature sensor. This one burner has a knob with different numbers on it because its heat is controled by a thermostat and not just by varying the current, as are the other burnser.
Nov 21, 2010 | Tappan Kitchen Ranges
We have a Maytag Electric Dryer, Model LDE512 , which leaves black marks on clothes while drying them. The dryer is about 18 yrs. old and has been working great except for this one problem. We have...
HI The drum is mostly stainless steel; The end that contacts the drum guide is just painted steel. After years of rubbing, some rust can form after the paint wears away,thus, causing the stain. Painting the bare metal (after removing all rust) and replacing the tumbler bearings,roller and roller shafts, will correct this issue and prevent it form happening in the future. You should also replace the tumbler seal while the unit is disassembled. Part numbers are below:
Tumbler bearings/Glides(You need two)- 306508
Roller - 12001541
Roller shaft - 6-3129480
Tumbler seal - 314820
Roller Shaft washer - 312535
Retaining Ring(shaft)- 410233
Jul 16, 2010 | Dryers
The grill will not light
It may be the regulator replace that and you should be ready to go!
Jul 06, 2010 | Weber 2780001 Summit S-470 Gas Grill
While grilling we had a flare up that quickly turned into thick black smoke rolling from our gas grill. we shut off the grill and got the flames out. what could have caused this? is it safe to try and...
If you have a grill that is several years old, some of your burners may be rusted and deteriorating, causing these large, out-of-control flames. It's definitely not safe to us in this condition. Remove the cooking grids and all parts above the burners and examine each burner with a flash light. It's also possible the seams have split which may be harder to tell that it's defective. If you can remove each individual burner to inspect it, do it and and make sure there are no restrictions inside the burner, like bug nests, debris, etc that could clog it and force gas out the venturi tube at the orifice. If you had moved or transported the grill recently before using it this last time, it may have jostled something loose or caused the rusted burners to fall apart so quickly. Hope this helps. Let me know if you need more assistance. Douglas
Jun 08, 2010 | Char-Broil CharBroil Master Flame Gas...
Two burners run too hot with yellow flame.
It sound like your back burners have a partial blockage or possibly are rusting or falling apart or have cracked seams. Remove the cooking grids and burner shields, and examine the burners closely. If you can't find a blockage inside (spider web, bugs nest, etc) then their condition is probably deteriorating. Let us know if you need more assistance.
May 21, 2010 | Weber Genesis Silver B Grill
Main Burners completely rusted out; control knobs to burner...
Get replacement burners and preheat them once. Then paint them with high temp enamle paint to withstand the temps of the grill. The burners are regular untreated steel and not the stainless that one would expect. Painting them will prevent them from rusting out after 2 years. Just make sure you temper them once before you paint them as they will expand a little. Then paint them and enjoy!
Apr 26, 2009 | Frigidaire GL38LKEC (LP) Grill
Burners keep going out
Remove the burners and clean the inside of the burners with compressed air and or a small long bottle brush.
The burner holes have a rust scale buildup in them.
Mar 21, 2009 | Weber Genesis Silver B Grill
Kenmore gas grill 141-16228
I would love to know the answer myself, I can't figure it out now that I have the grill half taken apart.
Jan 14, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Fire Magic FireMagic (LP) 14-S000C-0 Grill Logo
143 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
