Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
My featherlite weedeater brand blower has no spark.
How do I get the blower impeller off so I can fix it?
5 Suggested Answers
SOURCE: Featherlite will not start
Suggest , Clean Spark plug with Gas and wire brush.... drain all gas, add new gas with correct gas:oil mixture..... spray Gumout/Carb cleaner in air intake and spark plug hole.. these are the easy solutions to try.. good luck -Doug
Posted on Nov 24, 2008
spekgt
  • 60 Answers
SOURCE: willnotrecoil
Hello . First thing is remove the starter rope and check to see if the flywheel turn by hand . If turn by hand you have a bad recoil starter , if does not turn by hand the piston is seized . Remove the spark plug and put 2 or 3 drops of oil (2stroke mixing oil) on the spark plug hole and try to turn it again by hand . If still does not turn you have to replace the piston and maybe the cylinder .
Hope this help
Posted on Aug 29, 2009
bbreton
  • 437 Answers
SOURCE: Is the weedeater featherlite fl 1500 gas blower a
2 cycle engine takes a 40:1 gas mixture.
Good Day.
Posted on Oct 30, 2009
SOURCE: how do u change the impeller? on a model 2595 weedeater blower
how do I change the impeller on a barracuda 2595?
Posted on Jan 01, 2010
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Will not fire after replacing spak plug
if it will not spark after the plug change, then you need to go deeper to the coil, and the magneto, alot of times the magneto plate just needs to be sanded or wire brushed.
Nov 13, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Weedeater featherlite seized shaft
If you are talking about your crank shaft being stuck, there is nothing you can do that will work for the long haul. Usually what happens to cause this problem is running straight ( no oil added to fuel) gas to these 2 cylce engines. When you get a "lean seizure', the engine slowly loses power then quits. If you leave it alone for a while, the pull rope will be harder but it will start. The second tome it does this..........well your done. time to buy a new one. Sorry.
Nov 10, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
How do i take the spark plug out. i know it
find the plug wire
twist it slightly right and left and pull it towards you until it comes off the plug itself
find a 3 /4 inch deep well socket and 3/8 drive ratchet or equivalent
turn ccw to remove
Jul 05, 2009 | Poulan Featherlite Gas Blower, with Low...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
450 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
