Question about JVC TH-M606 System
Subwoofer JVC TH-M606 suddenly stopped functioning
The subwoofer suddenly stopped and the other speakers are fine. The unit has been in use for about three years. In the past few weeks the woofer unit started to just click on and off, today the unit would not turn on.
Turn on system, turn off system, green woofer light turns on for a second then clicks and turns off. There is no sound at all. Are there any solution to this problem?
    Scholar:
  • 113 Answers
Hiya, sorry that will have to go in for repair as it sounds like it may be protecting. Could be something loose but that would be lucky. Suggest finding a electronics shop in area that can assist. Best of luck
Posted on Jul 15, 2009
Hi I was wondering if you still had the rest of your home theater system. I am interested in the receiver if you have it still. Please let me know mrkeitsmo at gmail dot com Thanks
Posted on Nov 30, 2009
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
I CANT FIND A SP PWM505 CABLE
Regards, Tony
I need a remote for my TH-M606 subwoofer, how do I get a replcament?
encompass .com formerly vance baldwin .com will sell jvc to the public..
Sep 08, 2010 | JVC TH-M606 System
Subwoofer clicks and quits
The power amp that drives the subwoofer has quit. This will require repair. It is likely that the replacement you got from Ebay was defective as well. Not un-expected as I get stuff to repair from there all the time.
Your original unit failed in a manner to shut down the power supply. The replacement has a good power supply but a only fried sub amp.
Aug 10, 2009 | JVC TH-M606 System
Hello, I have all working speakers for the JVC TH-M505 home theater system, but the control center/receiver gave out. Do you know if I can use them with the JVC TH-M606 HomeTheater Control Center? Thanks...
If the JVC m606 requires a stipped wire to connect them then they should be fine just make sure you connect the right speaker to the proper output if your speakers have a specified connector on the end then you would have to cut that off and strip the wire. if your m606 requires a specified connector for the speakers then you would have to change the connectors out for the proper ones.
Mar 07, 2009 | JVC TH-M606 System
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Aug 12, 2008 | JVC TH-M606 System
Bass speaker stops working every now and then
Hi, Ive finally found the problem with my system :o) Its not the subwoofer its the DVD unit!!! think outside the box. Mine was randomly switching into headphone mode, so i pluged some headphones in took them out and walla its working fine. Not sure why this happaned perhaps some dirt or something else got inside there???? Let me know if this helps
Apr 07, 2007 | JVC TH-A85 System
SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Oct 21, 2006 | JVC TH-M505 System
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
May 19, 2006 | JVC TH-M606 System
JVC TH-M606 System Logo
747 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
