Question about Ricoh Aficio 450 Copier
Savin 2545 throwing error code SC672. - Ricoh Aficio 450 Copier
  • 183 Answers
Open the operation panel the cable which connects the controller and the operation cable might be not good attached or something like that.
The operation panel you might open by unscrewing the two screws on the front of the control panel and then pull the panel towards you.
Inside you will see some cables see if they are good connected or just disconnect them and connect them again.
If that not fix the problem than you have problem with the controller.
You might do the same procedure like with the panel.
Just remember to turn off the machine before you
pull out the controller.
The controller can be pulled out by unscrewing two screws on the left back side of the machine where you connect the machine with computer you cannot miss that part because the hole machine is with white plastic and that part of the machine is metal part.
Posted on Jul 15, 2009
  • OfficeServiceAjnc
    OfficeServiceAjnc Jan 26, 2010
    i had update the firmware and the problem is still here i still keep the machine in my service department for future investigation the latest think what i have done is replaced the cables from the controller to the scanner unit and the control panel so i still wait do the problem will appear.
    This problem for me is still on a pending place,if somebody have something new please post it
    Regards Ickoajnc
  • 48 Answers
Make sure you have the latest firmware for the controller and engine especially. Bugs in the firmware can also cause intermittent controller errors
Posted on Oct 20, 2009
How to set the error code sc 672-11
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/49446-sc-672-mpc300.html
Mar 22, 2017 | The Computers & Internet
SC672
do not know the language post in english
Jun 26, 2014 | Savin Toner C3030, C2525
How do I wipe the hard drive from a SAVIN 2545 Copier manufactured in 2002?
you can use aomei partition assistant, it is free and has the feature erase hard drive, you can see this tutorial: http://extend-partition.com/help/wipe-data.html
Jan 11, 2013 | Savin Office Equipment & Supplies
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
Dec 26, 2009 | Savin Office Equipment & Supplies
Error code sc726 savin copier 2545
SC726 indicates a finisher shift tray malfunction.
Nov 02, 2009 | Ricoh Aficio 1035 Copier
Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
1,163 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
