Cameras Logo
Michele Jensrud Posted on Dec 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fully charged battery reads as a dead battery in camera.
Battery is fully charged but sx30is reads a dead battery and will not take pictures. I have already tried replacing the battery.
abdul rauf
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Canon Expert 483 Answers
  • Posted on Feb 10, 2016
abdul rauf
Canon Expert
Level 2:
Dedicated:
Answers
483
Questions
0
Helped
95807
Points
726
it could be a software problem. if the camera doesn't get the battery's information this will occur the center terminal of the battery must be clean, similarly the contact inside the camera.
if it works for a little while, try to reset to default manner.
5 Related Answers
A
Anonymous
  • Posted on Mar 13, 2008
SOURCE: Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
Anonymous
  • 3 Answers
  • Posted on Mar 20, 2008
SOURCE: BATTERY dead. how to charge?
The battery is removable and the camera came with a charger that you connect the battery to and plug into a household socket.
A
Anonymous
  • Posted on Jun 23, 2008
SOURCE: "CHA" message - will not take picture
believe it is the film card. Try a different one.
Anonymous
  • 178 Answers
  • Posted on May 12, 2010
SOURCE: Battery not charging ?
Advise you to buy a new Digital Camera Batteries for Canon PowerShot SD1100 IS
Replacement for: CANON NB-4L
,cheap and good performance.
Anonymous
  • 6831 Answers
  • Posted on Dec 14, 2010
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Kodak Easyshare Z740 turns off while trying to take pictures constantly
There are a few possible reasons why your Kodak Easyshare Z740 camera might be turning off while you are trying to take pictures:
  1. The battery might be low or dead. Try replacing the battery with a fully charged one to see if this fixes the issue.
  2. There might be a problem with the camera's power supply. Try cleaning the battery contacts and charging the battery to see if this fixes the issue.
  3. There might be a problem with the camera's firmware. Try updating the firmware to see if this fixes the issue.
  4. There might be a problem with the camera's hardware. If the camera is still under warranty, you should contact Kodak for service. If the camera is not under warranty, you may need to take it to a repair shop to have it fixed.
I hope this helps! Let me know if you have any other questions.
Battery
have you tried using other brand of batteries ?
if you use rechargeable batteries, try them fully charged at another device and see if they last that long. if they last more than in the camera, then your camera might have an electric issue
I have a low battery indication with a fully charged battery on a Sony DSC-F717. What do I do?
First, even a fully charged battery may not be working right - VERY common.
Does the camera do this on two batteries, one old and one much newer? (I say this because lithium batteries are good for about 500 charges - if you are over this, the batteries will always read weak...)
A service shop can test the camera and see if the battery is reading correctly. A service shop may allow you to try the SHOP's good battery in your camera and see if it reads right. If OK, you need a new battery.
The service shop can reload the operating data into your camera - I have fixed them this way myself.
If not, the circuit board that handles charging and batteries may run you $275 plus labour. (The board is not repairable)
Camera still takes pictures but LCD screen remain black(lit, differnet from when screen is off) at all times. Batteries are fully charged.
Please make sure to check if the battery is fully charged. Second, check the menu option for battery saving mode and turn it off. If the battery is getting old and not charging fully anymore the priority of the camera is the shooting mode.
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
1helpful
My battery charger shows (green) fully charged when it is dead
THis is really a sign of a bad battery that is always being detected fully charge but its really drian , so it will be better for you to replace that battery.....
1helpful
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Batteries
Hi, This might be a case of the defective batteries (though brand new). Most if not all rechargeable batteries including Li-Ion batteries have only so much shelf life. The unit might be new but have been with the dealer for sometime. Probably your best bet would be to bring it back to the dealer and ask for a replacement camera or at least the batteries. Show him the fully charged indicator and how quick it will be gone when you try to take a pic. Of course, you would need your warranty card, proof of purchase and any other documents normally asked for complaints like this, Hope this give you an idea. Good luck and kind regards.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
