Question about Sewing Machines
Why cant i install futura ce 150 softwRE with windows 10?
  • Sewing Machines Master
  • 12,731 Answers
Dollars to donuts, bet your current software is not compatible with Windows 10.
Posted on Dec 30, 2015
    Top Expert:
  • 9,098 Answers
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
SOURCE:
I asked do you have an updated version for the CE-150 sewing machine . Embroidery software that is comparable with windows 10?
The CE-150 software update page claims that the version 3.0.1.3 update is compatible with Windows 10. See http://futura-support.com/products/ce-150/software . You will need the original installation CD in an optical disc drive. If your current computer doesn't have a CD or DVD drive, connect an external optical drive. These use a USB port or two - the second port is for power - depending on the model.
I hope this helps. If you don't have the original CD, you'll need to find a copy. I don't know of any trustworthy sources that still have the original disc.
Jul 25, 2018 | Sewing Machines
Futura ce-100 driver for windows 10
if you have it installed, right click on it and go to properties, find the compatibility tab , click on that click and highlight wuin 10, apply and close
or go to properties , find the drivers tab , click on that and go to latest driver upgrade
Jul 03, 2016 | Singer CE-100 Futura Computerized Sewing...
I have a Futura CE-100 and got a new laptop with Windows 7 and can not get the software to install. Gets to 100% and won't complete. How can I fix this?
First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set of instructions at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
I hope this solves you're problem. Happy embroidery!
Nov 23, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer CE-150 Futura can not locate driver software?
Most probably you have a pc with Windows 7 or Windows Vista/XP 64 bit that are supported since latest Futura software versions. For 64bit support you will need a version 3.0.0.7 and higher, for WIndows 7 support a latest update 3.0.0.9
http://www.futura-support.com/downloads/ce150.html
Feb 20, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Futura Ce-150. Do I need special
List of supported by Futura software design formats could be found in the software manual or on futura-support site:
http://www.futura-support.com/futuraSw/embformats.htm
Feb 06, 2010 | Singer CE-100 Futura Computerized Sewing...
For Singer Futura CE 250. New laptop with windows 7? Loaded software & tried 64 bit Vista update patch - it doesn't work. Is the newer patch available for download? Can't use Live Update because...
Update with WIndow 7 support is already available at:
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
Jan 03, 2010 | Singer CE350
Is the Singer CE-1oo Futura Windows Vista compatible? Also, can you put a #1 card in it to do the alphabet?
No it's not, All Singer futura users should be intitled to a 100% refund, or Singer should install new chips in the c-100's for former users. This is obsurb! you invest in the machine, and when the software upgrades itself, you are unable to use your machine. This is so awful
Nov 07, 2009 | Singer CE-100 Futura Computerized Sewing...
CANNOT FIND DRIVERS
I just bought a new Futura CE250 & had the same problem.
I fixed my "can not run an x86 build of this utility on x64 platform" by visiting the futura support website & downloading a service update. I have a computer with Windows 7 installed. There are also updates for Windows Vista & other operating systems as well.
The website is www.futura-support.com
When you are there, click on the link on the left for "Service Updates."
The actual link to where I downloaded my udate is: http://www.futura-support.com/downloads/ce150.html
HAPPY EMBROIDERING!!!!!
Sep 23, 2009 | Singer CE-200 Quantum Futura Computerized...
When I tried to load the software for my Singer CE 150 i got this message: Futura Software is not installed in your computer. Install the application and repeat the setup. I have windows xp. I have...
Run a disk cleaner through it and clean the disket with a dry soft cloth. After awhile the disk drive will get dirty and it cant read a disk.Do this once a month and you should not have anymore problems. Go to your local dollar store and pick one up.
May 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
1,019 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
