Replacing door switch on unidentified dryer
Each terminal is not the same size on most of the 3 wire door switches. Also one side of the switch usually has a white wire and the the other side has a light and the motor wire. Note: if you get em bass ackwards the motor will run with the door open. Light will be on with door shut dryer wont run.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: REPLACING POWER CORD
White to center, red on Right, Black on left, Green goes to case or external ground screw.
SOURCE: My dryer has a 3
to a screw on the rear of cabinet there may already be a wire connected there if so remove it and tape it off install green ground wire there
SOURCE: Using 4 wire plug on 3 wire dryer
YES TAKE THE GROUND WIRE OF THE NEW PLUG AND CONNECT IT TO THE FRAME OF THE DRYER UNDER AN EXISTING SCREW OR USE A SELF TAPPING SCREW THE FOUR WIRE SYSTEM WAS PUT INTO THE CODE MOSTLY TO INSURE GOOD GROUNDING ON MOBILE HOMES AND THE METHOD WILL WOKE FINE AS I HAVE GIVEN YOU
SOURCE: help with door switch wiring.
Just found that my neighbour works for comet
Got full PDF. Whiring is as follows:-
3=Gray
4=Brown White
5=Pink White
SOURCE: I have an old maytag electric dryer model #DE608
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
