Question about Whirlpool GEW9250P Electric Dryer
Control lock stays on and nothing else works on the panel. No other lights, no other controls. Disconnected power overnite but nothing changed.
The sound button is the button that you wish the sound to go on when the load is finished drying. Thanks for the advice, I was worried I just bought them and already broken.
Posted on Oct 20, 2008
  • Whirlpool Master
  • 19,396 Answers
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
We also had a problem with the control locked light that kept us from doing our drying...(so I tried to dry 2 loads of clothes on our clothes line in snowy cold football weather...later with the advice above we held down the Auto Dry Level button for 3 seconds and shabang it works again. Thanks for all of your advice and experience on this page. Hope someone benefits from our experience. Pulling out the plug did not do anything to reconfigure the computer inside.
Posted on Nov 09, 2008
I read the response on how to unlock my dryer however now I can find my sound button to press in order to unlock the problem?!?! HELP
Posted on Apr 04, 2008
To unlock the control button, hold down the sound signal button for a few seconds and it will unlock your dryer.
Posted on Jan 13, 2008
Thanks for helpful solution
Posted on Jul 19, 2008
Thank You for the info. I moved me dryer yesterday to replace the vent tube and accidently touched the off button. Iheard a beep. I didn't pay attantion until this morning when I needed to dry some clothes I decided to wear to work that the controls were locked. I held down thecontrol button for louder/ softer for the count of one thousand one, one thousand two and before i could count to three POP! Unlocked!
Thank You again.
Posted on May 07, 2008
Jandy rs4 indoor control panel lights up but nothing displays
trade controllers if when switched problem moves bad controller if problem stays inside bad wires or plug
Aug 18, 2012 | Jandy Aqualink Rs4 One Touch Control...
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
2007 Marquis. No interior lighting. Power door and truck locks do not work. Keyless entry dark. Originally the truck release would work intermittently from the door button or the key fob. A day later...
You pobably have a problem with the lamp control module , or the SCP serial data network . Vehicles that have more then one control module , like your vehicle ! The modules share info an send control messages on the data network . The door lock's are controlled by driver door module an is also on SCP network .
Communications Network Information Module
The first step in diagnosing these type problems would be to hook up a professional type scan tool . Check codes an see if the module's are all talking .
Your best bet , take it to a qualified repair shop .
Dorman Lighting Control Module Installation Crown Victoria Marauder Grand...
what is lighting control module and what does it look like on 2004 Mercury...
Mar 23, 2017 | 2008 Mercury Grand Marquis
Control locked light stays on after load is finished.
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please let me know. I hope this corrects the problem for you.
Mar 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not go on control locked light stays
You may have inadvertently locked the control panel. Before assuming you have a malfunction, read the following: The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The electrical systems have all gone crazy. Windows, engine lights, head lights, power locks won't function properly. I disconnected the battery and reconnected it to try and force a reset of the control...
90% probability you gave a ground wire issue at your fuse/relay panel. Most of the relays work off the same ground wires and you have relays for a majority of those "gone crazy" items.
Aug 03, 2008 | 2002 Buick Rendezvous
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool Dryer GEW9250PW0
the control panel is bad / it is also called a user interface
Nov 20, 2007 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9250P Electric Dryer Logo
460 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
