Question about Microsoft Windows XP Professional
Lost my water!
My FSX was running fine. All of a sudden all my bodies of water turned brown! Any help! tks.
  • 198 Answers
Make sure all your drivers are updated. Reinstall the program that is doing this and for the sake of everything dear in this world, don't drink the water.
Posted on Jul 15, 2009
Why is my ATC window empty
Make sure you did not accidentaly press the SCROLL LOCK key or also go to Settings/General/Air Traffic Control and make sure both ATC boxes are checked.Hope that helps.
Jul 31, 2014 | Microsoft Flight Simulator X for Windows
Is a small amount of brown moisture coming out of A/C w/cold air & slightly squeaking fan upon yearly startup on kenmore model 253.70101 acceptable : should i run it longer than 1 minute.
Brown is rust.
Painted metal outside for 2 yrs eventually rusts (ergo: brown drips) The fan is exposed to heat/cold/wet and the sintered bronze bushings may have lost their lubrication and/or the shaft is corroded, causing squeaks. Take the case off and try to lube the shaft bearings with oil, not WD40.
May 13, 2014 | Heating & Cooling
Installed FSX & it worked fine yesterday. Tried to play it today & it says my graphics card doesn't meet minimum requirements. What gives?
Once you reboot or restart your system, FSX will run the checks that it didn't when you installed it hence the message. Upgrade your card and you will be okay. Suggest an Nvidia GTS250 if you want lighting fast graphics.
Jan 23, 2010 | Microsoft Flight Simulator X for Windows
Have not run the FSX for many months now but hv reinstalled it now but meantime cannot find my CD cover -thus got no key code anymore -so cannot activate the FSX
Only way to do this is to contact Microsoft and tell them you lost the code. They may not allow you to have another code as many are using cracked copies. (not suggesting you are). There is an option on the install when you get to the register screen to contact them, then you give them the number that shown on your screen. Good luck!
Jan 15, 2010 | Microsoft Flight Simulator X for Windows
FSX Not responding. Uninstalled every application and add-on. Re-installed FSX, but still will not respond
This is a registry issue. Get yourself a good registry cleaning program, uninstall FSX, reboot the PC. Run teh reg cleaner, then reboot. Now you will be able to install FSX okay. Good luck
Oct 20, 2009 | Microsoft Flight Simulator X for Windows
Paint skin not showing up on Flight Deck 5 planes
Check that you are running FSX and add-ons in administrator mode. This sounds like a user rights issue.
Jun 14, 2009 | Abacus Flight Deck 5 Expansion Pack for...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Printer is printing browns as green
Your printer cartridge is running out of ink. Replace your cartridge.
Odinn
Sep 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Washer
Anne,
The lint filter is clogged preventing the pump from draining all the water from the tub. Open the little panel on the front lower left of the machine, unscrew the lint filter and clean it. Make sure you drain the trapped water first (before you remove the filter), by pulling out the little rubber hose (you'll see it) and removing the plug from the end.
BW
Apr 02, 2008 | LG WM-2277HW Front Load Washer
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
