Question about Garden
The manual recoil starter I pulled starter slowly two or three times and then cord was loose no resistance what is the problem?
  • Garden Master
  • 27,944 Answers
You need to pull the cord sharply to deploy the clutch so it engages the motor. If nothing happens or the cord doesn't retract, the return spring may be broken or the starter clutch is faulty.
You can remove the pull-cord unit and check. or take it in for service.
Posted on Dec 29, 2015
    Master:
  • 595 Answers
Sounds like the starter drive is jammed. Look for a large cog azt the back of the starter cord on the motor, manually push it in the opposite direction to the spin created when the cord is pulled.
SOURCE:
L pulled starter cord on my Homelite line trimmerHLT25cs, it would not engage and I heard a noise as I pulled . there was no resistance on the pull, but it recoiled just fine. what do I need to do?
try service manual via http://www.manualsonline.com
For your machine. Depending on age the "clutch" is not engaging on the shaft for some reason. It may be that some screws have come loose or missing. You may need to buy a new recoil mechanism.
Oct 28, 2018 | Homelite Garden
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
Coleman powermate vangaurd 9hp. how long is the pull start rope?
no set length on any recoil repair
old one will be stretched or broken
melt cord end for ease of fitting and no fraying through holes
and finishing knots
feed one end into recoil internal through outer and inner casing
then knot
set recoil spring into correct position and tension
cord is at least three times around recoil
leave excess cord out for pull handle and later adjustment
then cut .. melt end .. feed thought pull handle
then adjust as you test recoil off the motor
then fit to motor.. pull a few times
and final adjustment of cord length at the pull handle
Oct 13, 2016 | Coleman Electrical Supplies
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Broken spring in recoil starter on lawn mower
While I have not done this on newer model lawn mowers, I have replaced recoil springs in the past. Here's what I did: First you need to pull the spark plug wire off so the engine will not start. Then block the flywheel with a piece of wood to keep it from turning. Then, using another piece of wood such as a short (6-8 inch) hardwood dowel placed against the ears of the recoil drive, and drive it in a reverse direction (clockwise) with a hammer to knock it loose. It may take several sharp blows to break it loose. The recoil drive is reverse threaded to keep it from coming loose when the engine is running. Once the drive is loose, remove it to get access to the recoil spring which must be replaced if it is broken. With a new spring in place, rethread the recoil drive counter clockwise until it is finger tight. Then, tighten it down with one sharp blow against the wooden dowel.
Jul 10, 2013 | Garden
I have the toro ccr 2450 recoil start snowthrower and the recoil starter is not pulling properly. It's very hard to pull for some reason and shouldn't be frozen. It will allow me one smooth pull and he...
You have to understand its a cord spulled around a recoil spring. The coed likely didn't rewind correctly one time. However the entire unit unbolts with three screws.Remove the unit from the engine and check the cord and realine the core raping path as well as check the return recoil spring function. If you can not realign you can replace the unit as a part. After the first pull the engine has pressure to and that makes it harder to pull to.But try re alinging the assembly i have to do it to mine and its a 1964 and it still works
Dec 13, 2010 | Garden
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
On pulling the starter cord, there is a rattling noise as if a nut has come loose. The motor does not kick over.
When you pull the starter cord, three things are happening inside;
The cord is spinning the spool that it is wound on, the spool has a gear or molded teeth which engage the motor through spring-loaded levers, and a coil spring returns the spool to it's original position...hence the name "recoil" starter.
The first possibility is that the gear has come loose (if a mounted gear) or broken (if molded to the spool), and the rattling is the loose part(s) flopping around instead of engaging the motor.
The second possibility is that the lever springs are a bit dirty/rusty or bent and stuck out of position, and the gear/teeth of the spool are just banging across them instead of engaging.
Start by removing the plastic cover(s) to gain access to the starter rope's origins, ie; the spool and the starter levers.
The recoil spool with sping are likely attatched to the cover as a unit, so you don't have to go any deeper into the recoil.
Check the drive gear/teeth for a solid mount and teeth damage (they are saw-tooth shaped), then check the 2 small levers mounted to the crank for free swing and solid springs...a drop of oil or WD40 at their mounts won't hurt, just wipe the excess and while you're there, clean the magneto face and the magnets on the crank with a little WD40 on a rag.
* Don't despair if they look fine...it's entirely possible that they were stuck out of position until you pulled the recoil, and a decent cleaning will keep it from happening again.
Mar 29, 2010 | Garden
Howdo I fit a new pull start cord on a ryobi 25cc
remove the plastic housing to gain access to the recoil. Pull the cord slowly all the way out,this will cause the spring to wind up.Clamp the recoil wheel so it will not return to its original position,be carefull the recoil has tension on it not remove the old pull rope and thread the new one in and thru the hole of the recoil tie knot.pull on the cord to take tension off and at the same time remove clamp. Slowly allow the recoil to wind the rope in and reinstall on unit.
Dec 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
110 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
