Question about Sony SDM-HS73P 17" LCD Monitor
Black screen My computer starts, but the screen is black. It lights up pink for 2 seconds when i press on the input button on side of the monitor, or if I flick the on/off button on my monitor. It seems to be running normally behind the blackness.
  • gateway1450 Nov 27, 2007
    same problem
  • TakeyoshiMI Dec 22, 2007
    I got same problem. Ibought SDM-HS73 at July/2003.
  • 983 Answers
Check the brighness and contrast of the monitor from the menu button ... try giving reset ....
if same problem persists then the monitor CRT tube may be gone
jsut go expert technician and tell the problem...
if so the technician will recharge the tubes...
Posted on Feb 06, 2008
Sul monitor Acer AL1515 compare Input Not Supported
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor. What you can do is restart your computer to safe mode first. These are the steps going into safe mode:
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
NOTE: For Windows 7, it should be similar to the steps for Windows Vista.
Jan 16, 2011 | Acer X193W LCD Monitor
All of a sudden, the screen display went black. When we restart the computer (Windows XP), we see the initial windows logo but nothing else -- EXCEPT, pressing and holding the screen's "INPUT...
Very doubtful. Either you have a defective or corrupt display driver, or possibly a malware infection. Is that a laptop or notebook computer? If so, is there a VGA port for an external monitor? If do, try using a known good external monitor.
Apr 28, 2017 | Sony SDM-HS74P/S 17" LCD Monitor
I have a LG flatron W2053TQ i cannot press any button every button i press say osd locked
Press and hold the MENU button for about 5 seconds. This should unlock the controls. On some monitors it will be the power button that you need to press for 5 seconds to unlock.
If none of this works, it may be a malfunction needing servicing.
Aug 08, 2010 | LG L1740P (Black, Silver) 17" LCD Monitor
My screen lights for about 2 seconds and then goes black. If I press the off button and then press it on, I get two seconds of screen (good quality) and then black again. It acts like a cold-solder fault.
My LCD had the same problem. I just finished changing the 25V 1000uF capacitor and now its working just fine. The capacitors are located on the board that have the power input. Check if any of the capacitors (the tall cylindrical structures) have bulging tops, if they do, try to replace them Please bear the polarity in mind when you play with capacitors.
Jan 11, 2010 | ViewSonic Computers & Internet
Screen cuts off image
To see the button on the right hand side of this monitor you will need to shine a really bright light on it, but the buttons from top to bottom are: 1, up-arrrow, down-arrow, and 2.
  1. On the side of the monitor press the 1 button to activate the menu.
  2. A configuration menu for the monitor will appear; from that menu highlight the "Input Select" menu item using the up and down buttons on the monitor; when you have the item high-lighted, press the 2 key.
  3. A new menu will appear, and then you can select the menu item called HDMI on the left and PC waaay over on the right. Select this menu item with the up and down arrows and when it is selected,
  4. And press 2 like you did in the previous step.
Apparently there's some sort of a strange difference between using this monitor as a "video monitor" and using it with a computer.
Nov 02, 2009 | ViewSonic VX2433WM 23.6" Monitor
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Corporate Computer
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
160 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
