Two speed fan has 3 wires going to pull chain switch. 3 speed will have 4 wires. Are you sure you have the correct switch for your fan?
There ARE FANS that WILL work in an ordinary light circuit... you just need to match the 2 wire switch... to the 2 wire fan...!!
Most notably Casa Blanca has two vintages of switches... each requiring their own interface at the fan ... Hunter also (once upon a time) had switches with (carry around) "remote" controls.
Black... switched (hot... turn off the breaker first)
White = neutral (return)
and bare copper is the safety ground
All good (all as it should be)!
ABSOLUTELY NO ROCKET Scientists are required here...
It is not at all UNREASONABLE to expect your salesperson to KNOW WHAT YOU NEED... to finish your install.
A word of caution... Be sure to read and HEED the part where they tell you to reinforce the mounting to support (long screws, cross-bar, block of wood... etc) the additional weight and motion of your fan assembly!
No big deal... this is a NORMAL APPLICATION... if the WIRES DON'T MATCH.... your sales person needs to update their resume!
You are THE CUSTOMER: Saving a few $$ on a DIY project is NOT a sin.
Have fun... be safe.
If single speed fan you have 3 wires and ground
if 3 speed fan you have 5 wires
if 1 speed 2 wires are are the power and the other one is a capacitor wire at 1.3uF 1.5uF 330v you need to have the wiring chart for the motor or you could work it out with a ohm meter or seek the help of a sparky
Mindless meaningless jibber-jabber designed to scare.
Not helpful!
Also found a Hampton Bay switch... $50 on Amazon.
But you HAVE GOT to remember... these 2 wire switches are PROPRIETARY...
Casa Blanca fan needs Casa Blanca switch
and Hunter needs Hunter...
... blah, blah, blah...
http://www.amazon.com/gp/product/B00S2U5...
Lin, I'm sorry to hear about your troubles trying to get your ceiling fan and light to work. Something very similar happened at my father-in-law's house. He ended up getting a few bids from licensed, experienced, and reputable electricians. I'm not sure what happened, but his ceiling fan & lights now work. http://www.genesiselectric.com/
