Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Noise when draining
Seems like that when it drains it is making a loud noise and it is the part mounted under the bottom of the washer in the center. Is the drain pump going out?
  • 297 Answers
It has just broken from it's mount,it may last for awhile.can not fix must replace unit.
Posted on Jul 15, 2009
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Maytag MAV7550AWW makes very loud noise while draining, although it still drains and spins out.
Check the pump. Maybe a coin or something got in the impellers. Another is to check the belt and pulley along with the mounting of the pump.
Jan 15, 2014 | Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Drain line makes loud noise
Yes, by all means, check for obstructions in the drain line. Also check to see that the motor mounts for the drain pump are not damaged. Sometimes the veins in the drain pump get broken off and cause an imbalance in the pump which seems like a clog!
Jan 01, 2013 | KitchenAid KUDS03FSSS Dishwasher
When dishwasher is draining it makes a very loud noise but it does drain
May be solenoid valve makes a thud noise. It is normal.
But if it was silent during earlier days usage and the noise is notice now, then check it's mounting. For this you have to open the back door of your machine.
May 17, 2010 | Dishwashers
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Loud noise when draining
You need to tilt this machine back and remove the drain pump from under the machine and check for anything stuck in there eg a hair clip or coin etc. If there's nothing stuck in there you may need to repalce the drain pump. Cheers
May 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Off balance/loud knocking
check the inner tub with your hands , if tub is very loose? theres a screw loose or broken at the bottom of center mast, AJ
May 10, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
Jun 13, 2007 | Kenmore 40052
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
164 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
