Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
Hi, I've got an International 560 tractor that
Hi, I've got an IH gas 560 tractor that won't start. I turn the key, push ignition button and it goes click. I can charge the battery so it indicates a full charge and still it just clicks. If I use jumper cables connected to my truck it will start. I've had the regulator and generator tested, both are ok. Is it wiring? Where do I start? Thanks.
I think, if you look at the wiring from front to back you will most likly find one or more breaks in the insulation around the wires. This will cause a drain to the starter or a short to the system. Solution: track and replace all falty wires and ammeter
Posted on Nov 09, 2009
  • 10,865 Answers
It sounds like the starter has gone bad. The only fix there is to replace it.
Posted on Jul 14, 2009
  • Joe Hogan Jul 14, 2009
    Problem Solver:
  • 14 Answers
Check for bad wiring and charge the battery and test it
Posted on Aug 17, 2010
START TRYING TO LOOK FOR A SIMPLE BAD CONNECTION, GROUND POSSIBLY. TO SOLVE OUT THE STARTER TAKE IT OFF AND SEE IF IT WILL ROLL FREELY WITH A TYPICAL 12 VOLT BATTERY
Posted on Mar 18, 2010
3 Suggested Answers
SOURCE: What kind of batteries go in a 706 I.H. tractor?
its 12 volt or 6 volt
Posted on Apr 19, 2010
  • 14 Answers
SOURCE: electrical charging & discharge problem
weak or bad genorator check amps and also check all connection and fuse and "no -oxyidation" will help corrosion reduction. worng size bulbs and there may be resistance some place
Wiring diagram 560 farmall 560 tractor
try searching for a tractor forum like OLDIRON
Jan 05, 2016 | Farmall IH Tractor 460, 560, 660, 2606...
Ih tractor
You will need to bleed air from the injector pump it self. Next to test glo plugs pull from engine and connect a wire to the body to the earth. Turn on ignition and press button for a few seconds and they should glow. If not check for power to the plug
May 06, 2013 | The Times Case Corporation Tractors...
560 will not start
start with silinoid or starter drive. obviously check to see the crank is free
Dec 20, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
Dash layout on farmall 560
The operators manual shows a cigarette lighter in that location. It would be just to the right of the starter button. I have an IH 560 diesel, so that's where the glow plug button is located.
Jul 29, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
Where do you check hydraulic fluids on a 460 international tractor
I own one. Most have a plug in the top of the trans/hydro case to the left and rear of the gear shift leaver. It takes a 3/4" drive to open it. I use an extention and brake bar or ratchet. The fluid should just all most reach the opening. the books state it should hold 8 to 10 gal. I have found my 460 Utility holds almost 20 gals.
Jan 04, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
I have an international 460 tractor and i ma trying to find the serial number. All I have found for a number is 10865, but that doesnt fit into and of the serial number references that I have found. Does...
I have a International mid sixties 460 tractor. Have drained fuel, changed fuel line and filter. Carb has been taken off cleaned no issues. Will start and run for a few minutes sometimes longer than others. Seems like there may be an issue with the governer. Any ideas what to try next. Thanks
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Need a rebuild kit for int updraft carb
this is a type 6 part.
Means = no longer avalible.
you will have to get from wreakers
Jan 03, 2009 | The Times Case Corporation Tractors...
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
1,375 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
