I have a Thomas Pacconi classic combination turntable, radio, cassette player, CD player. Worked well for several years, now the CD player has quit - at first it skipped, then it stopped, trapping CD inside. When powered off, rested a while - it eventually gave up the CD - but have not had confidence to try again. Have read similar problems - but not a fix. Is there one? Can the CD player be replaced? If it helps, the model number is TPC-MSE-800.
  • 93 Answers
SOURCE: HELP! Pleeeease! CD stuck in undercabinet player--opens but cd remains inside
It seems that CD stack on player's axis.
Posted on Oct 05, 2007
SOURCE: Need replacement power cord, might be part HCJ SU-7P.
i have one
Posted on Sep 02, 2009
SOURCE: CD player acknowledge CD, starts to play, then stops
replace belt in lazar assembly and clean lazar eye with quetip with rubbing alchol
Posted on Oct 07, 2009
  • 195 Answers
SOURCE: I've owned an Antique Apparatus CD-91 counter
Hi Nick,
If you still have this problem I would contact Bruce Wentworth in the USA, listed below are his details.
Regards
Alan Hood
ami-man
UK
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com/
Posted on Mar 26, 2010
sunil06
  • 394 Answers
SOURCE: cassette door will not open
below the push button their is a tiny whole , take a needle of about 3---4 inches in length and insert in that whole and your door will slightly comes out then open it with your fingers
Posted on Jun 14, 2010
I need an owners manual for The Thomas Pacconi Classic Model # TPCMSE 805 for my 82 year old father who has lost his and it needs a new phonograph needle and the cassette player is not working.
not sure about a users manual or other parts unit is belt driven
you can by the stylus
turntableneedles com
http://www.turntableneedles.com/THOMAS-PACCONI_c_50123.html
some thing easy diy if no sound while playing a cassette
try cleaning the head (silvery bit )
of the cassette player with cotton bud and metho
Jul 02, 2016 | Audio Players & Recorders
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
Thomas Pacconi Model TPC-MSE-800 turntable runs slugglish. 78 runs fine but 45 or 33 runs slow. I removed belt cleaned it and platter. I put a drop on oil still same problem. Do I need a new belt? This is...
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Dec 16, 2010 | Seth Thomas Pacconi Turntable
We have a Thomas Pacconi record player and the band underneither the turntable has stretched out. The band is black, about 1/4" wide, and round. Can you help us.
TBirdMM, thanks for the advice. I was turning that dial this morning tweaking the rpms and it worked! Strangely enough I actually broke the white dial off, but when I spun a 33 on the 78 setting it played right on! Thanks!
Does anyone know why that dial only effects the 78rpm setting, and if there is a dial for the 33 rpm setting?
Jun 09, 2009 | Seth Thomas Pacconi Turntable
Thomas Pacconi turntable turns too slow
My older Thomas Pacconi turntable was also turning too slowly. Rather than replacing the belt or needle, I tried using an eye glass repair screwdriver to alter the trimmers inside the motor. But the changes didn't take. Then I tried trimming the power to the motor using the larger trimpot next to the motor with the motor itself set to the 78 rpm setting. But the adjustments to the trimmer didn't get the platter to spin slow enough - it wouldn't play an LP. To get the speed down further I replaced the 1K trimmer with a 10K trimmer I picked up for a buck at Radio Shack and successfully adjusted the turntable down to down to 33 1/3 rpm usage. All that was needed was a soldering iron and a 10K trimpot to get the job done.
Dec 28, 2008 | Seth Thomas Pacconi Turntable
Speed problem on Thomas Pacconi Turntable
probably need the rollers rebuilt
check out needledoctor.com
Dec 02, 2008 | Technics SL-1200MK2 Turntable
Philco turntable cd with cassette player all i get is the cassette playing nothing else works where can i get it fixed here in washington state
just find a local electronic repair shop near you
look in the phone book for electronic /electronic repar shop
i have had to repair these before and the selector chip has failed because of a resistor letting to much current and voltage go into the chip , repair cost $40-$50 depending on the dammage
Oct 29, 2008 | Philco (R) Classic Turntable CD Shelf...
243 people viewed this question
 Grubhead
Grubhead
