Question about Garmin GPSMAP 76 GPS Receiver
My Garmin GPSMAP 76csx GPS turns itself off. Now it won't turn on. I've tried 4 sets of batteries and a master re-boot.
  • bi3wannabe Jul 14, 2009
    There is no vertical line...
SOURCE: garmin gpsmap 60csx won't acquire satellites
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Posted on Sep 24, 2007
SOURCE: GPS wont boot up
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Posted on Dec 16, 2007
reef runner
  • 7 Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
SOURCE: Garmin gps 72 not aquiring satelites
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiate
Posted on Mar 24, 2009
SOURCE: Garmin gps
Try this link to Garmins driver downloads: http://www8.garmin.com/support/download_details.jsp?id=591
USB Drivers software version 2.2.1
Posted on Oct 13, 2009
My gpsmap76csx shuts off on its own, and i've changed batteries
use usb data cable to turn the power on, if power is stable then probably something wrong with the batteries compartment.
May 23, 2011 | Garmin GPSMAP 76CSx Handheld GPS GPS...
GPSmap 76CSx is not acquiring satellite
Update the unit using Garmins WebUpdater program, this may fix your issue as there was a chipset update that is crucial to acquiring satellites. here is a link to the software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 07, 2011 | Garmin GPSMAP 76CSx GPS Receiver
I cant uploaud waypoints to gpsmap 76csx
Try reloading the software, then load the program, then attach the GPS.... Should start communicating at this point. Make sure the cable is seated correctly....
Feb 14, 2010 | Garmin GPSMAP 76CSx Handheld GPS GPS...
My Garmin GPSmap 76CSx was working just fine. After leaving it unused for a couple months with a pair of alkaline batteries installed, I tried to turn it on. It would not come on. I checked the battery...
Try connecting it to USB and powering it up, to confirm that unit still works overall. You probably damaged battery connectors. Check if you can clean the connectors better, otherwise you may need to do some soldering to fix them, by yourself or n a repair shop. Check with Garmin if they have suggestions: a leaking battery should not disable a GPS.
Dec 10, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
I have a Garmin 76CSx that freezes on start-up screen, no buttons have any effect. Only way to switch off is to pull batteries out.
I had the same thing. Seemed to be a faulty SANDISK 2GB MicroSD card. When I pulled it out, the unit worked again.
Sep 30, 2009 | Garmin GPSMAP 76CSx GPS Receiver
While down loading maps the 76CSX just quit. The batteries are good. When I turn on the GPS it starts then fads away like there is no power, yet I have tryed 2 sets of new batteries.
It sounds like a corrupted upload. Reset the unit and retry the upload.
Usually reset is done by pushing page and enter while powering up
Apr 22, 2009 | Garmin GPSMAP 76 GPS Receiver
Serial number
Pull off the battery panel. In-between the 4 pin connector and the battery compartment you will find an 8 digit number.
Note the serial number is different from the unit ID which can be found by using the Garmin Mapsource software tools, or by going to:
Menu >> Setup >> System >> Menu >> Software Version
Mar 30, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from www.garmin.com
enter: www.garmin.com
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
regards
frankie
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
You need to do an auto locate. This also corrects your time issues (wrong date and/or time will be corrected. To do an auto locate do the following.
  1. Start with the unit turned off.
  2. If you have a GPSMAP 76, GPSMAP 76C, or GPSMAP 76S, hold down the Page button. If you have a GPSMAP 76CSx or GPSMAP 76Cx, hold down the Zoom Out button.
  3. While holding down the first button (Page or Zoom Out), press and hold the Power button.
  4. Continue to hold the two buttons until the Satellite page displays. You can then then let go of the buttons.
  5. Finally, let the unit sit outside with a clear view of the sky. Allow about 20-40 minutes for the unit to acquire satellites.
May 01, 2008 | Garmin GPSMAP 76 GPS Receiver
Garmin GPSMAP 76 GPS Receiver Logo
494 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
