Question about Hayward SAND FILTER, PRO SERIES
Calcification on swimming pool
I have mineral/calcium build-up on my in-ground gunnite pool here in Arizona. Enough so that dirt that falls naturally into the pool accumulates on the sides and is now VERY difficult to sweep and vacuum. People have told me to drain the pool during the cooler months and have it acid-washed. But is there anything I can do NOW without draining the pool and during these hot months? I'm in Phoenix, and I hate to give-up my pool use now.
The hayward pool buggy barely gets the dirt off the sides of the pool now, and the vacuum is as strong as it has always been. when I put the soles of my feet on this dirt, it sweeps right away, but when I brush it or vacuum it, it has trouble due to the extreme mineralization on the pool surface. I need to get that surface smoother so the action of the vacuum works better.
  • Ilene May 28, 2013
    Just wondering if you used the scaletec?? Did it work??? Thanks
  • 128 Answers
Size the gallonage of your pool and purchase Scaletec. Double to dose. 4 to six weeks the scale will dissolve and brush off
Posted on Aug 23, 2009
First thing to do about chemicals for above ground sand filters
the values I set for my customers pools is as follows:
chlorine 1.0 - 3.0 ideal
ph 7.4
alkalinity 100 ppm
calcium 200 ppm
stabilizer 50 ppm (saltwater pool 25 ppm)
These values will provide balanced swimming pool water
Jul 01, 2014 | Blue Wave Sandman Above Ground Sand Filter...
What is lime?
Hi Ken,
Lime is a calcium-containing inorganic material in whichcarbonates, oxides and hydroxides predominate. Strictly speaking, lime is calcium oxide or calcium hydroxide. It is also the name of the natural mineral (native lime) CaO which occurs as a product of coal seam fires and in altered limestonexenoliths in volcanic ejecta.[1] The word "lime" originates with its earliest use as building mortar and has the sense of "sticking or adhering
May 02, 2014 | Computers & Internet
Gunnite swimming pools
the crazy cracks may not be a problem as they should only be in the surface finish. If you are worried see if there is a clear epoxy finish that you can spray / paint on the surface to seal the cracks
Jun 21, 2013 | Pool & Spa
Why is my swimming pool water cloudy?
Could be first signs of algae growth.
Check the chlorine levels.
Check the pH levels.
Jul 23, 2012 | Pool & Spa
Machine says CALCIF What does it mean?
CALCIF usually indicates "calcification" which is a buildup of calcium and other minerals. I don't believe you would normally see this indication on a microwave oven. Coffeemakers often indicate mineral buildup by indicating "DESCALE" or similar.
Descaling or removing mineral deposits in a coffeemaker usually requires running the coffeemaker with white vinegar instead of water, and no coffee ground or filter. Three or four "brewings" is usually all that is needed to remove the deposits. Simply run several more brewing cycles of clean water to rinse all the internal components of any vinegar and the job is complete.
If this answer isn't applicable - please tell me model number of the appliance that is displaying the CALCIF message, otherwise, please rate my reply "4 thumbs up" if it was helpful Thanks!
Aug 15, 2011 | Siemens Microwave Ovens
Smoothe surfaces underwater feel gritty... granular substance is adherring to the walls of the spa
Is this a gunnite spa/pool? Normally a rough surface indicates water that is too acid (I.E. pH is way low) The water wants to be 7.4 pH (7.2 to 7.6) ... and it will get there one way or the other. If this is the case in your pool, the water has taken the lime from the gunnite to satisfy the high acid level.
Please check your pH and other factors. Make sure your water is properly balanced to stop the lime migration ... Also check the calcium level ... should be around 300 ppm though it is ok as low as 175 and as high as 1000.
May 01, 2011 | Pool & Spa
Our ta keeps falling by fifty in like just a few hours why?
Presumably you are referring to Total Alkalinity - assuming that your test kit/procedures are OK, the reduction is caused by a build up of acidity in the water. The addition of sodium bicarbonate will neutralise the acid; the fact that the ta keeps falling suggests that you either have a large amount of acidity and you aren't adding enough sodium bicarb to complete the job, or you may be adding acid in the form of a pH decrease chemical. To raise the total alkalinity by 40ppm you need to add sodium bicarbonate at the rate of 700 grams per 10,000 litres of pool water. The desired ta is about 100ppm.
You don't say whether this is a swimming pool or a spa pool - if it's a spa pool I suggest you drain it and start with a clean slate, so to speak. If it's a swimming pool you are probably being timid with the sodium bicarb!
Jan 24, 2011 | Pool & Spa
Water is cloudy after shocking pool on filter then pouring in one bottle of super fall out diluted,recircjultaed for two hours shut pump off over night so flock woulsd settle to bottom , but I went out to...
Let your filter run for a couple days, you will get the undisolved solids out of the water.
Cloudy water is junk floating in the water. "Super Blue" is a product I use to make the junk stick together to be collected by the filter.
Aug 25, 2010 | Intex 2500 Above Ground Swimming Pool...
Brown water
When you fill a pool with new water ... the first thing to do is remove the metals. Did you do that? This should be done with a sequestering agent ... "Metal Out" is one generic name. Treat according to the package instructions. You should treat for metal before any other product is added to the water. I believe you are seeing 'rust' from the iron in your water. The salt did it If you said green I would say you have copper or mag in the water. You may have a variety of metals in the water. Nitrates? Get rid of them ... they will eat the CL as soon as you add it. If yours is a gunnite pool, expect serious staining. To remove staining, consult your pool professional.
It is probably too late for the above ... let the CL go to zero or add some thiosulfate to kill it. Get it at the pool supply place. Use according to package instructions. Then go back to the start and add the metal out, etc.
After the metal is out of the water, you should raise the CL level - 2 to 4 PPM - using liquid or dry CL. Your filter should run 24/7. When the pressure on your filter increases 10 PSI, you should back wash - NOT BEFORE!
Check your Alkalinity ... get it to 100. When this is done (and this will not happen in minutes - it will take hours ... move slow on adding chemicals. You already saw what speedy adding of chemicals does (Brown Water)
When the Alk is 100, (use Sodium Bi Carb or dry acid for this) then adjust your pH - (use Bi Carb or dry acid for this). Your pH goal is 7.4 (7.2 to 7.8 is acceptible).
Now is the time to add salt (after your water is balanced!). There is a chart in your salt machine instruction manual that will tell you how much salt to use. Your goal should be about 3200 ppm salt. If the salt is low, you will not make CL at all. If the salt is high, you will have to dump some water to dilute back to around 3200 ppm.
You should consider adding Cyanuric Acid to your pool to around 60 - 80 ppm. Cyanuric acid will protect the CL in your out of doors pool. Just a side note, dry CL normally comes with cyanuric acid in it for stabilizing. Since you are making CL, you will need to add the cyanuric acid to protect it.
You don't say if you are gunnite or plastic ... if gunnite - you should consider your calcium level. Calcium should be around 300 ppm. (you can go as high as 1000) To much (more than 1000), you have to dulute it with water that is lower in the mineral. If there is little or none, the water will take the mineral from the surface of your pool - not good. Again, your goal is 300 ppm
This is all information that your Pool Tech guy will charge you $ for - or you can get it free from your pool chemical supply place. You also got it free here at FixYa.com from this volunteer CPO (Certified Pool Operator) question catcher. Please remember to evaluate this response.
Thank you for your interest in FixYa.com
Jul 12, 2010 | Intex Automatic Salt Water System for ...
Humidifier filter clogged in one month with white residue
thanks for you question,
the residue that you are seeing is Calcium, it is a natural mineral that is found in all water, the easiest way to remove the calcium build up from your humidifier screen is to use (CLR) it is a calcium, lime and rust remover, a simple diluted mixture with water, then soak the screen for about half an hour, rinse the screen then reinstall, a soft water system would help with the calcium build up as well, but tend to be alittle on the spendy side, your could try inline mineral filters that need replacing yearly, I really hope that helped ansewr your question, let us know with some feed back, thanks again for your question, mr.grzz
Jan 21, 2009 | Honeywell HE220A1019 Whole House...
Hayward SAND FILTER, PRO SERIES Logo
334 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
