Question about Zyxel P660HW-D1 Router
I can play online with with my xbox 360 with some friends but not others. I think it may be because of my nat.
    Novelist:
  • 154 Answers
Here's the complete list of ports you may have to open.
TCP 80
UDP 88
UDP 3074
TCP 3074
UDP 53
TCP 53
Reference: http://support.microsoft.com/kb/908874
Posted on Jul 17, 2009
  • 126 Answers
Verify you have uPNP enabled on the router and that should do the trick.
Your router may not support it, so if not, you can setup a port fowarding rule for TCP port 3074 to forward to the IP address of your xbox 360
Posted on Jul 14, 2009
How to unmute yourself on xbox 360
Hi there I can sort understand what you mean and I think this is the answer. If you cannot be heard normally in chat when online even though your mic is turned on or you have made sure that in preferences, you went in to audio settings and made sure you were not on mute? My guess is your having issues with your NAT settings as this can affect you chat settings when online. For example, xheck your NAT status and if it is MODERATE or STRICT then this is why. If you NAT is OPEN then it is because the players you are playing with have a NAT issue. MODERATE and STRICT NAT's will limit what you can do online, including chatting.
Hope this answers your question :)
TEEMAN
Nov 01, 2011 | Microsoft Xbox 360 Console
Me and my gf are trying to use quickplay matchmaking but every time we look for other friends online she always get booted i have put her in the same party and tried in viting but it still boots here
This is because her NAT settings are strict, or moderate and not accepting information from other networks. Look into finding out how to open the NAT settings on your router/modem on Google. You must first find what type of router you have, and find out from there.
Mar 09, 2011 | Activision Guitar Hero Warriors of Rock...
HI, im trying to play halo3 on xbox 360 but the xbox say that i have strict NAT and therfore can not join other games online with my friends..... what do i do? it has worked just fine for 1,5 year, but now...
its a setting in your router..if the ISP reset your box for any reason, the network address translation (NAT)may have been lost.
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | NetGear RangeMax WPN824 Wireless Router...
I can't connect to my friends on my xbox 360
Go to the Xbox360 System area and run the Network Test and see how it goes. A Strict NAT setting will allow you to play online but will affect the connectivity somewhat. In my case I had to log on to my Router and Allow certain ports access. My router had Xbox Live as an option to open, yours might too, have a look.
Goodluck.
Jul 17, 2009 | Microsoft Xbox 360 Console
Can't join party of friend on HALO 3 while I have an OPEN NAT
The case is the way the network is setup are you connecting him via a router? Make sure your NAT is open on the router as well.
Jun 09, 2009 | Microsoft Xbox 360 Console
NAT restriction
your internet connection is not strong enough for the xbox live sevice... it may be week and have short connection failures, causing it to say that, try pluging directly into your broadband instead of using a router
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Cant have private chat or play games with friends
This should solve your problem
For most devices that use NAT, port forwarding is not required to connect to Xbox Live. This is especially true if you use an Xbox Live certified device. Sometimes, you may have to configure port settings on a non Xbox Live certified router or gateway.
If there is a firewall device between the Xbox console and the network device, you may have to configure the firewall to enable communication on specific network ports. If the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," you may have to configure port settings.
The following ports must be available for Xbox Live to operate correctly:
� UDP 88
� UDP 3074
� TCP 3074
To open the ports on your router see this handy website here,
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
which gives you a step by step guide.
Before opening the ports you must give your Xbox 360 a static IP address (manual) be sure to use an IP address that no other item on your network is using and is fairly high up in your range, for example if your router's address is 192.168.0.1 then you should use something like 192.168.10 for your Xbox 360.
You can also enable DMZ (Demilitarized Zone) on your router, which will open up all the ports to your Xbox 360, however NEVER use this on a PC's IP, see your router's manual on how to do this.
Once the correct ports are open for your Xbox 360, then your NAT should say open.
Nov 26, 2008 | Microsoft Xbox 360 Console
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Ps3 ali
maybe they have to many friends or they have been blocked from another person
Feb 21, 2008 | Sony Playstation 3 (PS3) Console
Zyxel P660HW-D1 Router Logo
151 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
