Question about IBM Computers & Internet
Computer still won't come up.
I was able to go in and set the time now it says error 163 and 173 then it says off >on. What should I do now??
Pls send me p4i65g chipset driver and graphic card driver that may problem to my computer plss
Posted on Jul 15, 2009
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
LG GS 290- Java application not working it shows error Resource Not available
Your System memory is full (Check it: Phone Settings -> Memory info -> Handset common memory -> System memory). I had the same problem. After deleting some Java applications or games, you won't see this error.
Mar 07, 2011 | Dryers
Isass.exe system error keeps coming up, insufficient system resources exit to complete the API
1. Remove all viruses or spyware or worms, if there are any.
Open Task manager and check how much physical memory and PF (Paging file) is being used.
2. If usage of both physical memory and PF (Paging file) is high
Click start>> Control Panel >> System >> Advanced >> Performance Settings
3. Click on Advanced tab and click Change under Virtual Memory.
Click Custom size and set the Initial size to 1.5 times of the RAM size on the computer and Maximum to 3 times.
4. Restart the computer
5. Empty some memory space on the "C" drive
6. Click Start >> Run >> Type CMD >> Click OK
7. In command prompt type "chkdsk /r" press "Enter"
8. Type "Y" and press "Enter"
9. Restart the computer
10. Also if you want you can defrag
Sep 19, 2010 | Acer Aspire One PC Notebook
Hi Everyone, I have a problem with "Astro Office 2000" Software. It's kind of Astrology (kundali making / match making) software. I have this software in my computer since quite a long time. It was...
Hi, You can try to check the Virtual memory of your computer to fix the problem. click start> right-click my computer > choose properties> then click on advanced > under performance click on settings > click on advanced tab again > then click on Virtual Memory (change button) > and choose system managed size. > then restart the computer.
Hope this helps Cheers!!!
Aug 17, 2010 | Computers & Internet
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
CMOS settings are wrong
Hi there.
It sounds like the motherboard battery needs to changed for a new one, check out this link for an in depth tutorial on what battery to get and how to install it >>>>>>>>
http://www.hardwaresecrets.com/article/81
Remember to set the date and time once you have your new battery installed.
Good luck and thanks for using FixYa!!
May 12, 2009 | PC Chips (M925G) Motherboard
I have one scx-4300 samsung printer this time show printer error
try to use to set your printer factory default configuration
Maintenance > Of clear Of setting > Of all Of setting [OK]3.
In the service menu (TECH MODE):MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
MUSTAFA BULENT KILIMCI
YUNUS COMPUTER CEO
COMPUTER EXPERT
e-mail & msn : address mbkilimci@yunuscomputer.com
Mar 24, 2009 | Samsung SCX-4300 Monochrome Laser...
Google Talk problem
To resolve this problem adjust the Date and Time Properties of your computer.
Sep 15, 2008 | Google Talk
Computers & Internet Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
