Pedals or crank assembly squeaks/creaks when standing... cause/solution? Thanks.
SOURCE: Squeaking peddles
1) Lube inmediately, and tight the bolts+nuts, and replace any parts worn.
2) Follow the instruction manual according the schedule maintenance
God bless you
Detach
the ends of the pedals from the crank axles. Spread a layer of
machine grease over the crank axles, then reattach the ends of the
pedals.
Remove
the bolts connecting the pedals to the swing arms. Detach the pedals
from the arms, then spread a layer of machine grease over the axles
on the swing arms. On some models, the bolts may also serve as the
axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
