Question about Weber Genesis Silver B Grill
Can't get male part of manifold fitting apart from female hose en
Can't get male part of manifold fitting apart from female end of hose to replace regulator hose with new. Does Weber sell just the male end that fits through the manifold opening?
  • 30 Answers
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
Thanks Bill - much appreciated. However, the female section of the connector is mounted in a casting on the rear of the tractor. The only accessible part is the outer face of the fitting.
the part that you screw is on the male end of the hose
IF it is not as described you will have to check with a dealer
by looking at the male fitting you will see that it is blocked off with a small pin out of the center
this is a non flow valve that closes of the hose to stop the oil from running out and to stop dirt from getting in
there is a similar operation in the female connection and when pressed together one opens the other to allow oil flow
when pressed together you slide the screw bit up to the thread on the female bit and do it up
quick connect hose fittings are universal in construction and used universally across all manufacturers and hose manufacturers
Nov 14, 2017 | Cars & Trucks
Hydraulic connections on a chamberlain 4280 tractor
should be quick disconnect
unscrew the male outer cover and pull apart
make sure that there is no pressure in the hose ( attachment at rest)
there is a series of balls in the female connection that move out of the way of the male fitting and when coupled the outer case screws down and locks the balls into a groove i the male part
Nov 13, 2017 | Garden
Picker male female
You can get an adapter at you local hardware store
1/4-in x 1/4-in Threaded Adapter Fitting
Jan 30, 2014 | Whirlpool Refrigerators
I have a Hans Grohe shower head extension #27479000 that requires a 1/2" male NPT nipple extending 5/8" from the finished wall surface. I found the female pipe thread in the 27479000 is threaded...
NPT and NPS are the same. Screw away! If your female thread is plastic and your male thread is metal, you must be careful not to overtighten as overtightening can crack the plastic on the female thread. Good luck, and don't forget your teflon tape. 4 to 5 wraps is good unless you have heavy duty gas piping teflon, then use less.
Apr 14, 2017 | Hansgrohe Plumbing
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
The hose connection nipple is smaller than the garden hose-connector and leakes. Do I need a special hose or will putting plumbers tape on the nipple stop the leak?
No, that would probably leak too. What you need to do, is go to your local hardware store or home center (Plumbing Dept) and purchase a female to male connector. The female end is to connect to the unit's male hose connection and the other (Male) end, needs to be the same size for garden hose connection. Make sure that you use an appropriately sized washer for the Female end.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Danby DDR5009REE Dehumidifier
Bought a weber genesis 320 Problem with the Weber Genesis E-320 Propane Grill bought a weber genesis 320 in US and need to replace the hose / regulator that it fits to German LP gas cylinders. Which...
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
May 08, 2011 | Weber Genesis E-320 Propane Grill
I am trying to change fuel filter on 1995 ford econoline f-350 It appered that the fuel lines were held on by push on retaining clips but after removing the retaining clips I still cannot seem to get the...
Yes you do, The first clips you removed are the secondary clips. The lines have to be released from the inside. Heres the info.. Cobra :-)
Removal
  1. Open safety clip.
  1. Fit Tool T90T-9550-B (5/16 inch) or T90T-9550-C (3/8 inch) to coupling so that tool can enter female fitting.
  1. Push the tool into female fitting to release the retaining fingers from the formed male tube end.
  1. Pull male and female fittings apart.
  1. Remove the tool from the disconnected fitting.
  1. Inspect the fitting for any internal parts that may have been damaged. Fuel tube should be replaced if internal parts are damaged.
Jun 05, 2010 | 1995 Ford Econoline
I can not change tools without letting all the air out of the compressor. Reason is I have a hook on my left hand. If I had a shut off value on the out let I wouldn't have to empty the air each time I...
i think quick connects will work for you, as long as you are talking nail guns or impact guns etc..
you can hold the tools between you legs and use your good hand to work the fitting
That is how i did it when i cut my finger off
good luck
Nov 05, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Everything is unplugged, I just need a wiring schematic to plug everything back in
Does the motherboard have a "purple" socket?
Does your keyboard have a "purple" end?
If so, join the male to the female,
rotating the male until the stiff pins line-up with the holes.
Does the motherboard have a "green" socket?
Does your mouse have a "green" end?
If so, join the male to the female.
The end on the monitor's video-cable has 3 rows of pins;
there's only one place on the computer with 3 rows of holes.
Notice that the sides of the male are tapered,
so that it only fits ONE way into the female.
Similarly, the female end on the power-cord is tapered,
so that it only fits ONE way into the back of the computer.
Note where it connects -- there may be a "rocker" switch,
with a '1' and a '0' on the ends of the rocker.
Press the '0' end down before you reconnect everything.
Press the '1' end down after everything has been reconnected.
Do your PC speakers have a green tip?
If so, then connect the male from the speakers to the green female socket.
Sep 14, 2009 | 3Com Computers & Internet
Weber Genesis Silver B Grill Logo
356 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
