Question about Pioneer TS-WX65A Car Speaker
On faceplate it says "sub out"
I've checked all the wires and still cannot find the problem. I have also checked that the power source was strong and alsop the fuse.Also on the right speaker there is nothin plugged into it but it still works.
  • 30 Answers
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
What fuses have constant power supply in a 2005 Chevy equinox? I'm trying to get power to a pioneer under seat subwoofer.
ALL subwoofers need a minimum 10 gauge wire power source.Run a 10 gauge wire to a relay then to the battery with a fuse or circuit breaker inline which matches the subs amp power needs.
Use a switched power source to the relay from any accessory fuse.
If you try and feed power to a sub from existing wiring a voltage drop may result and the sub amp will not only sound bad but have a short life.
Capacitors are added to bigger systems just for this reason as sub amps can be VERY power hungry.
May 01, 2017 | Seat Cars & Trucks
Crossfire vr2000d wont stop cutting out
Bad ground, possibility of some wires touching
Oct 25, 2017 | Crossfire VR2000D Car Audio Amplifier
Faceplate only works with applied pressure to the front screen
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com
May 25, 2012 | Pioneer DEH-P6800MP CD Player
Hi Ive brought a Sony 2dx-gt590ui and sub and amp got it all wired up but the sub only works on radio can you tell me what Ive done wrong???
You can try to connect the remote power wire at amplifier to main power with a jumper wire if sub works with cd and other sources.Then check remote wire from behind radio or you can simply connect remote power wire to a another switched power source from fuse panel.Just make sure its a clean dedicated power source from fuse box and make sure it turns off amp..Goodluck
Sep 23, 2011 | Car Audio & Video
I have a Sony CDX-GT310 FM/AM Compact Disc Player with detachable faceplate. The unit still plays fine, but the display on the faceplate quit working. I've tried resetting the unit as well as cutting...
check the connectors between the faceplate and the unit carfully they can get damaged with constant removing/refitting if not the faceplate and/or unit is faulty
Dec 09, 2017 | Sony CDX-GT310 CD Player
Buzzing sound when sub is on even without turning my amp on, if you can call me on my phone 909 938 9219 it be better for me thanks, i am little slow with my computer, please help
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights.
I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still buzzes with no cables or anything external attached there's an internal problem.
Apr 30, 2011 | KEF Audio PSW 2150 Speaker
I just installed my Naxa NX-670, and now when I attach the faceplate, nothing works.
If you run into this problem, be sure that all the fuses to the wiring leading from the battery to the radio are good, then be sure that the yellow wire is attached to the constant power source and the red wire is attached to the acc/ignition power source.
Oct 22, 2009 | Naxa Electronics NX-670 Car CD/ MP3 Player
When i wire my sub up,it flexs out and stays there with no sound..
You have dc voltage on your output, not good. Do you have another source to hook up the sub to? (even low power) If you can hear it with low power source, try a regular speaker on the sub output (At No Volume Level) I would be willing to bet the sub output is faulty, or wired incorrectly. Hope this helps.
Aug 20, 2009 | Rockford Fosgate Car Audio & Video
Subwoofers not getting music
looks like you need to check the SOURCE of where the signal is coming it could be that your CD car stereo SUB opt. is turn off , check the menu of SOURCE and switch to SUB on , hope this helpful
Apr 28, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Pioneer TS-WX65A Car Speaker Logo
49 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
