Question about Dishwashers
Don't have a manual for ARISTON LS 620 A DISHWASHER
I just need to know which setting to put it on for plates, coffee cups, plastics and knives and forks, rinsed saucepans etc
  • 297 Answers
Light wash
Posted on Jul 15, 2009
What kind of cutting board is the best?
I think plastic is the best. Wood harbors bacteria, glass ruins your knives. Plastic ones can be cleaned well and they even can go in the dishwasher.
Jan 14, 2013 | Home
Ariston Dishwasher Detergent dispenser
you have 2 options.replace the timer on the unit or when you start a load wait 10 minutes and put a half cup or a little more of detergent into the water in the dishwasher.
Jan 05, 2008 | Ariston Technologies LL64WNA Built-in...
How to load a dishwasher
Hello Lona Harrington, here is how the manual for my fridgearie dishwasher tells me and how I load it .
1. Upper Rack is for smaller items. Cups, small bowls,sippy cups, plastic bowls. all face down.2. Lower Rack is for larger items. Plates pots and pans. The plates should be upright. pots and pans face down.3. flatware basket. This is ware I disagree with the book manual. The manual says to put the tines of the fork facing upright and the same for the knives. I have young children and they are great helpers, but I don't want them hurt so I put all the sharp points down.Manuals are available on line free Hope this helpsJoe Connollysealstonetops@gmail.com
Dec 03, 2011 | Frigidaire Dishwashers
Dishes are not cleaning well
I often get calls similar to this client: Over the past several weeks-months, have been getting a whitish film/deposit on pots, tops of some plastic cups, etc. You don't really see it on plates.
Typically this is caused when someone switches detergent usually to a liquid gel. It is almost always because we use too much soap.
One of my most appreciated recommendations follows:
My suggestion is to throw the liquid away and use the Cascade Complete or Finish tablets. Place one in the bottom of the dishwasher. Do not put them in the dispenser.
The reason for this is you want the soap (abrasive) at the front end of the cleaning process so that the last little bit of food that is left on the dishes (I'm assuming you are rinsing your dishes) is blasted off and then the dishwasher can "sanitize" the dishes with water that is too hot for you to handle. That is the real purpose of a dishwasher.
Keep in mind that if you rinse your dishes well before placing them in the dishwasher you can probably use the shortest cycle and save quite a bit of money on electricity and water over the course of a year.
Also, take a coffee cup and fill it half way with white vinegar and place it upright in the top rack with your next load of dishes. Do this for the next several loads and then once per month for as long as you own and use a dishwasher.
Sep 02, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 13, 2010 | Kenwood KDW243A Builtin Dishwasher
Dryer
Had the same problem and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 12, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
Ariston LS 620 A Dishwasher
Since, the pump doesn't stop working, it sound like a water level switch issue. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Aug 13, 2007 | Ariston Technologies LL64WNA Built-in...
Ariston LL64 doesn't start
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
Dishwashers Logo
970 people viewed this question
Top Dishwashers Experts
Owen Barnes
