Question about Universal Remote Control DIRECTV Universal Remote Control
What buttons do i push to input the codes - Universal Remote Control DIRECTV Universal Remote Control
  • 56 Answers
Every type of universal remote are programed differently. What you need to do is find the programming guide for the remote and follow the directions or try going to the manufactures website.
Posted on Jul 15, 2009
"Safe" keeps displaying on radio, locked out
You need to remove the radio back up fuse for at least 2 minutes (yeah, I know they say 30 seconds, but it hasn't always worked for me), then reinstall the fuse. It should show 1000 or something similar on the digital display. You need to have the 4 digit code to unlock the radio and depress a couple of buttons after entering the code.
Remember that you push the radio pre-set station buttons to enter the code; button 1 for the first digit, button 2 for the second digit and so on. You will then need to push another button on your radio to enter the code. The button that you need to push will depend on which type radio you have.
If you don't have the radio code, look on the trunk floor to see if the radio serial number or code for the radio is there. If the PDI was done correctly and the radio wasn't replaced, then there should be a sticker on the trunk floor area with the serial number of the radio and/or the code. If it isn't there, then the radio needs to be removed from the vehicle to see the code that is stamped into the metal body of the radio. This plus the VIN number are input into the VW information system (done at the dealership only) to obtain the radio code.
The instructions for inputing the code should be in the owners manual or radio suppliment as supplied by VW, when the vehicle was sold new. If you have the code but aren't sure about how to input the code, see the local dealership, they can do it on the driveway in a manner of a few moments.
If the radio requires to be pulled to obtain the code, expect to pay between .5 to 1.0 of labour at the dealership's posted labour rate to obtain the code and input it into the radio to make it function. They used to do it for free until they ended up doing something 10 or more of these a day, because everyone else was charging up to $120! to unlock and programme the radio!
Mar 04, 2013 | Cars & Trucks
Pulled radio to get serial # and now I can't get the radio to go into code input mode. it just says "safe" and the icon for pause is on
If you've entered a bad code a couple times, you need to wait an hour while the radio and ignition are on. Then, turn on the radio, SAFE should be displayed. Then Press the FM1 button and hold it down, then while holding down the FM1 button, press and hold the AM buttons so that both buttons are held down simultaneously. Release the buttons. Now enter the correct code using the radio pre-set station buttons (one through 4). Button 1 changes the first digit in the code "1"000, Button "two" changes the second digit in the code 1"0" "three" 00, button changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the FM1 and AM button simultaneously as before until SAFE is displayed, then release the 2 buttons, and now the radio should now work.
Jan 21, 2013 | 1993 Audi 100
The LED light was flashing (the remote was already programmed someone else programmed it for me) so I took out the battery and now I need to reprogram it. The instructions are in very tiny print and I
First you need to find the program button or input button. Almost all universal remotes are the same process for programing.Aim the remote at the tv and push the tv device button once then use the program or input button push and hold till the light blinks twice or stays on then put in your 3 or 4 digit code and press enter.
Jan 20, 2013 | Televison & Video
Need remote set up magnovax tv FOR COMCAST CABLE TV
Push the TV button on the top of your comcast remote, Push and hold the setup button. The TV button will flash once, and then twice more. After the flashes, you will input a 5 digit code, if it is high definition, the codes are 11454, 10802, 11198, 11990. If standard Def, the codes are, 11454, 10054, 10030, 10706, 10187, 10386, 10802, 11198.
Try those codes one at a time depending on which definition you have. One of those codes should work for you. If the first code doesn't work rinse and repeat the process until you find a code that will turn the tv on and off, and adjust the volume.
Good luck :)
Nov 04, 2009 | Philips Televison & Video
I can not get the emmerson tv i have to go into video mode. I do not have the origional remote that came with the tv or the manual. The remote i have is programed with direc tv. how do i get the tv into...
In the upper left hand corner of the DirecTv remote there is a button labeled "TV INPUT" just push that button. Each time you push it it will change the inputs for the TV. If that is not the problem, the remote needs to be programmed with a code for your TV. If that is the case push the MENU button under the circle in the middle of the remote. Scroll down to PARENTAL, FAV'S, & SETUP, push the yellow SELECT button in the middle of the circle, scroll down to SYSTEM SETUP, then scroll down to REMOTE and push the yellow SELECT button again. From there you should be right as rain. On my TV and setup, I have a device hooked up through DVI, but the TV won't recognize it unless it is powered on. In otherwords when pressing the TV input on my DirecTv remote it doesn't show the DVI device (PS3) unless it is powered on. I hope this helps and good luck. Please vote and leave a message.
Oct 30, 2009 | Emerson CR202EM9 TV
Reprogramming to my symphonic tv
What is the brand name of the Remote? You might be able to download or print off a manual from the manufacture's website, if they have one. but try this first, turn the TV on and push the code search button (If there is one) and press the TV button and aim it towards your TV, this should make the remote begin searching for the codes. If that doesn't work, try this, push and hold the code search button, usually the light above or below the button flashes 3-4 times then stays on, then push the TV button, it should flash once and then also stay steady, next input the code for symphonic, they are:
0906, 0520, 0324,0247, and 0004. Enter each 4 digit code and wait for a response. Usually the TV will trun off after the correct code is pushed. Sometimes you have to push the TV button again to complete the programming.
May 01, 2009 | Televison & Video
1993 SAAB CSE LOCKED STEREO
If this stereo is a clarion and original equipment and uses a a four digit code. First thing you do is with the power on to the radio, push and hold the band button for a few seconds until you see the word "code" on the radio display. Input the code and radio should work. If that doesn't work, then if you have tried to input a wrong code several times then radio will lock out. So what you need to do is
the radio has to be on for one hour uninterrupted, then you can do the band button procedure , code input again and hopefully the radio goes on. Hopefully this helps. Please advise results
Feb 21, 2009 | 1993 Saab 9000 Hatchback
Have set up a new SONY DVD player. How do I set my RCA Cable TV so I can play a DVD. My Channel Code is #3 on the TV
use the color coded wires that were supplied with the DVD player plug them into the inputs on your rca tv then use you remote and there should be a button that says input i know my rca tv does. Then you push this button and it lets the tv use the input plugs.If there is more than one plug in on your tv push the button till you see your DVD players on screen menu.
God Bless Greg
Nov 15, 2008 | Computers & Internet
RCR412C input button.
what tv is it? might want to try another code if the button don't work with the code.
Jul 11, 2008 | RCA RCR412C Remote Control
Sentry really big universal remote
the following is a link to the updated code list for the RMC-10, note it is in pdf format so if you do not already have adobe acrobat reader you will have to download that before you can read the code list. I will also leave the link to download the adobe acrobat reader in case you need it
Hope this helps
Carl
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
http://www.adobe.com/products/acrobat/readstep2_allversions.html
Feb 07, 2008 | Televison & Video
Televison & Video Logo
195 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
