Question about Insignia Digital-to-Analog Converter for Analog TVs
No channels recieved
The converter recieved 0 channels after scaning in auto or manual. the box is scaning channels in Mhz, but the cable company is transmiting in Khz. could this be my problem.
please help
  • lpaul55 Jul 23, 2009
    the cable and tv broadcasting is in KHZ, but the cable box and tv is scaning for signals in MHZ. therefore i am not getting any signals. What can i do.
  • 439 Answers
If you have cable already, you do not need to use a converter for your picture. You would still just hook your coax cable to the tv right from the cable inlet. The converter is for over the air signals only, so you would place it between your bunny ears and the tv to convert your signal for your tv.
Posted on Jul 14, 2009
No channel coming on screen
this tv needs a digital to analog converter box in order to recieve the digital tv channels that currently exist.
Apr 11, 2013 | Toshiba CF32H50 TV
Our cable company has upgraded to digital channels. This tv has the right equipment in it and should find the digital channels but doesn't. When I first did a digital channel search it grouped channels...
the cable company switched to digital just like everyone else, but that should not effect your viewing, they convert the channels back to basic cable so you can see the without having to do anything. If you want to watch "over the air" digital tv you need an outside antenna and television that can recieve digital signals, or put a digital convertor box on your set, but none of this makes any sense if you have cable because you are already getting the same channels over the cable.
Mar 19, 2011 | Televison & Video
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
I tuned the tv on and after it scane the channels the tv came i have atleast 60 channels now i only have 29... channel 30 says audio only 30 thru 60 no picture, and then the channels say like 30.20
Is your televison set to cable mode or broadcast mode?
Who is your cable provider?
Comcast recently, in my market disabled the ability to receive the new digital format unless you use their converter box.
Jan 04, 2011 | Televison & Video
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
SONY KV32V16...can't get all my cable stations.
I called our cable company about getting a converter box and it ended up I didn't need one after all. The cable rep told me to go to the menu and try the auto-programming. He was familiar with the TV I have and said that a converter box is not necessary. So, I tried the auto-programming and still didn't get all the channels...then I noticed on the menu for the channel set up there was the word "Cable" and after it it said "Off" so, I switched that to "On" and did the auto-programming, and Presto! I got all my channels.
Dec 25, 2008 | Sony KV-32V16 TV
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
TV's tuner will not recieve all channels
Since you are not using a set top box, you will probably only get channels up into the 70's, if available in your town, as most channels above this are digital, which analog cannot convert.  As for the digital tuner, I have the same problen.  It will not pick up any digital channels.  Because of this, I have had to get a digital box(why in the hell should I have a digital tuner?) to recieve digital channels.  I have the same tv you have, except a standard def.  If you ever find out why your digital tuner won't work, I'd love to know myself.  good luck, hope this helps.
Oct 06, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
269 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
