Question about Dell Latitude C640 Notebook
Dell c640 wireless connectivity problem
C640 will connect to internet fine with ethernet cable, but wirelessly on secured network will not connect to sites where data is exchanged- logins etc. Will work fine wirelessly on unsecured network. Any ideas?
    Scholar:
  • 181 Answers
Hi.
That's gonna be a permissions problem in the way the wireless device was set up originally. Go to network devices, properties (of the wireless connection) and check advanced options for permissions. Also check the way the firewall was set up, and if it allows the connection you are requiring.
Good luck
Posted on Nov 18, 2007
How do I get started with my home wireless internet service?
connect your computer with the router with help of an Ethernet cable.
configure the router and wireless signal by following the wizard
remember to put in a secure password on the router.
disconnect the cable and connect to the wireless network you just created.
if that does not help .. then call 1-877-805-1027 for expert help
Jul 31, 2015 | Dell Computers & Internet
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
How do I secure my wireless router? dell truemobile 2300
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 21, 2010 | Dell TrueMobile 2300 Wireless Router...
Wrt400n connects via ethernet cable, but won't talk wireless
you said every thing that connects with the ethernet is working. that means the wired part of the router is working. check the wireless settings of the router. Open the set up page of the router on the main computer. connect the main computer to the router with the ethernet cable.
change the wireless settings of the router.
WRT400N is a dual band router ( 2.4 GHZ and 5 GHZ)
You can create 2 different wireless networks. Make sure that the names (SSID) will be different for both the networks. For 2.4 GHZ change the standard channel to 6 and save the settings.
Go to wireless security and set the security mode to WPA Personal. set up password for the wireless network. You can use the same password for both the networks. Make sure that the Wireless MAC address is disabled.
Now try to connect to the new wireless network. and see what happens.
Click here for more information about routers
Mar 12, 2010 | Linksys WRT400N Router
The ethernet controller on my Dell Latitude C540/C640 Notebook has not worked in a while. I am able to get wireless internet access, but no luck when I try to connect to my router via a direct line. I...
If you are using Windows XP, go to Control Panel > Network Connections. Right click on Local Area Connection and then click Enable. (This is only applicable if the ethernet port is disabled).
Also, you may go to Device Manager (Right Click My Computer > Manage > Device Manager) and then check if the ethernet is disabled or has a question or exclamation mark.
If both dont work, your ethernet controller is broken.
Jun 07, 2009 | Dell Latitude C640 Notebook
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
How do you connect to the internet ?
what u can try is that install the lynksis cd on the computer and then open the network connection and then right click on the wireless network connection and then click on the view available network and then connect to ur network connection and it should work or else the best way u can do is that u can call up dell technical support and they will be definately able to help u to connect to internet cause i really cannot explain all the details here cause it need to be done troubleshooting on ur computer practically by connecting the router with the laptop with the ethernet cable and when u connect the internet with the ethernet cable then the dell guys can take the remote session in ur computer so that they can help u to connect to internet wirelessly.
follow 4 steps to connect to lynksis:-
In order to follow thesen four steps all u need to do is that just follow this link very caarefully and u will definate;y be able to connect to internet wirelessly with the lynksis..
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx#step1
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Internet problems
anneruth:
Is your laptop/desktop getting the ip address from your router (if you have one?)
Are you on a wireless connection or ethernet?
Go to start button, connnect to, show all, double click over LAN connection or wireless connection whatever you are using, properties, then support, please let me know if you have any IP in the first line?
Also if you are on a wireless connection, make sure your wireless NIC is NOT disabled, enable it. Let me know if you need help?
Hope that helped!
Regards
Dec 17, 2007 | Dell Latitude C640 Notebook
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Dell Latitude C640 Notebook Logo
210 people viewed this question
Alun Cox
