Question about Kenmore 17259 Free-standing Dishwasher
Wont accept water kenmore model 665
Will not stay connected to tap as soon as i turn tap on conecter shoots from tap when i only turn on tap a small bit water just leaks out baround conecter
  • 297 Answers
Need new hose connector,hose
Posted on Jul 15, 2009
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Why does my kenmore 665 dishwasher start pumping hot water even though its not turned on?
You might have a bad water valve, or a bad timer (especially if this dishwasher uses a mechanical timer - one that has a rotary dial in front).
Feb 24, 2015 | Kenmore 665
Kenmore washer water not filling
there is a inline mesh filter at the tap end of the hose but it is more that likely that the tap washer need replacing
it is possible that the inlet solenoid valve is not operating properly
if you have separate hot and cold water hoses and taps then either tap should produce a full flow when set if no taps get a full slow when selected , indicates a problem power board
Nov 05, 2017 | Kenmore Washing Machines
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
Kenmore dishwasher 665-1703 wont stop washing
Unfortunatly you are looking at the timer which is now built into the controller which would need to be replaced. If the relays are fused shut on the timer or the gears are missing some teeth then you will only get sofar I the cycle and the washer will just stay where it's. Sorry
Sep 08, 2012 | Dishwashers
Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Sep 30, 2009 | Kenmore Kitchen Ranges
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 | Dishwashers
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 17259 Free-standing Dishwasher Logo
102 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
