Question about Gaggia Titanium Espresso Machine
Ventalate screen Mine doesn't go off, so can't make coffee. I have tried everything!
    President:
  • 1,618 Answers
Try this open the hot water valve then push in the steam knob, if that works then contact your nearest distributor and tell them you want a new style steam valve, this valve is stainless steel and works a lot better than the plastic one in the machine.
Posted on Jul 15, 2009
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
Keurig
Check the needle that pierces the bottom K-Cup, those can clog which can cause it to run slow.
You might also try de-scaling it: http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
If this doesn't help, it could be an issue with the B60 itself. If it's under warranty still, call Keurig, they'll likely send you a new one. The B60's seem to have control board issues. Every once in a while mine acts up, and I have to pull the plug, reset it, and fiddle with it til it starts working correctly.
Jul 10, 2012 | Keurig Special Edition B60 Coffee Maker
Exact same problem as another reviewer: CCM901 my coffee maker side will not make coffee - the light is on but the plate doesn't heat it doesn't pull water up to make the coffee either - have had...
Hello, inn
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 24, 2011 | Emerson EM83701 Coffee Maker
My C1500 has started leaking water out the bottom. I think it is coming from the right-hand side, but not sure. It doesn't seem to be coming from the tank and it is coffee-colored water. Any...
I'm working on the same problem, I need someone who reads technical swiss-german to help. There is a pump on the bottom right that drives cold water into the boiler. The connector on the bottom of the boiler (brass to vinyl plastic) came apart on mine. On a german language expresso maker website there are several parts that address this problem, the difficulty I'm having is figuring out which part fits tthe boiler I have as apparently this is a problem on serveral version and there have been re-designed connectors (mine doesn't look exactly like the one in the picture
http://www.kaffeemaschinendoctor.de/ReparatursetsWerkzeug/Dicht-/Reparatursets/Jura-Reparatur-Dichtset-fuer-die-Heizpatrone::101.html
Jul 18, 2011 | Jura Capresso C1500 Espresso & Coffee...
The machine gets warm but the water doesn't come out. The screen reads that it's brewing, but then it just turns off and the screen reads "Ready."
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 27, 2011 | Keurig B50 Coffee Maker
Steam works, coffee doesn´t
Try to prime the machine.
Open the steam knob and press the buttom for coffee, when the water comes, close the steam knob.
Aug 24, 2008 | Saeco VIA Venezia
Venting
Try to make a cup of water(tea).
Aug 23, 2008 | Saeco Magic Comfort Plus Espresso Machine
Same problem
The printed circuit card is the problem, on some models the printed circuit card loose from the chassis.
Jul 06, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Vienna Digital
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
142 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
