Question about Intex Easy Set Pool 15x36
I have a intex above ground pool 18 x 42 and I need a manual to help me with the filter how do I put it on
  • 297 Answers
Go to intex.com
they have a few pdf files and also videos showing how to do it.
Although these are the salt water system it is still the same set up and procedure. Just pretend it is your pump when reading or watching the video
Posted on Jul 15, 2009
I have an Intex pool,with the pump that is attached to the side not on the ground and I want to put this sand pump,on but how do I do it
it should be fairly simple and there are local above ground companies that can help, ,you would need a way to attach your sand filter with hoses.
May 10, 2016 | Intex Pool & Spa
Pure Spa. where can I get an owner's manual?
Support - Intex
www.intexcorp.com/support/
The leader in Above Ground Pools, Airbeds and Inflatable Spas. ... Manual Pumps · Electric Pumps · Parts & Accessories · Electric Pumps · Floats & Toys · Pool Toys... If you don't find what you're looking for, get in touch with Customer Service.
2500 Gal Filter Pump (120v) - Intex
www.intexcorp.com/28633eg.html
Review the Trouble Shooting Guide in your Owner's Manual. Are any tools ... Can we use the pool while the filter pump is operating? Is it safe? No, due to ...
Oct 28, 2015 | Intex Pool & Spa
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
WHAT AND HOW DO YOU VACUUM INTEX ABOVE GROUND SALT WATER POOL
I used the manual vacuum that came with the pool during the summer because I actually got in the pool and vacuumed), but ultimately, now that it is cold, I went to the pool store and bought a much bigger vacuum (that still hooks up to the water hose) and then a longer pole. It's just too darn cold to get in the water during the winter. :-) Hope this helps!
Nov 02, 2012 | Intex Automatic Salt Water System for ...
How do i connect a salt water system to the pool
if you use a salt system in an above ground pool, the steel frame work will last less than 2 years before it rusts out
talk this over with the pool experts first and then have them help you with the system needed
Oct 25, 2017 | Intex Automatic Salt Water System for ...
We got a above ground salt water pool an it's turning a little green what would be the best thing to put in it.
The first thing to do is to shock it with vinyl to about 10 ppm. This should start the progress to blue. Follow the Intex instructions to make sure the pool contains the correct amount of salt and stabilizer. The pump, filter and chlorinator should be run continuously until the water has clarified. The chlorine should then be kept between 2 and 4 ppm. One last suggestion, the filter gets plugged more quickly when you have shocked the pool to get rid of algae so make sure you clean the filter to keep the flow up. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
Hi, I have let my intex above ground pool go green over winter and with summer approaching don't know if I need to add extra salt or something else to get the pool ready for swimming. It is a 14 foot,...
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
Oct 25, 2010 | Intex Automatic Salt Water System for ...
I just purchased an intex above ground pool and i need help on where to put the chlorine at
The problem with the floaters is they can drop out small pieces of tablets or granuales and cause bleach spots on the bottom of your pool. Use the skimmer.
Jun 15, 2010 | Intex Krystal Clear Model 635 Pool Filter...
How do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Intex Easy Set Pool 15x36 Logo
446 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
