Question about Maytag PYE2300AY Electric Dryer
My dryer is drawing 22 amps, the drum is turning fast. I am getting no heat for the clothes. The voltage is 240. I would like to see a manual so I can see if a belt is off or not. Thanks Tony
    Brigadier General:
  • 4,088 Answers
My guess is that the power socket in the wall for the dryer is incorrectly wired! 22 amps is about right for a functioning dryer, but not just the motor. The drum is turning, so the one belt is intact. First thing to check is the voltages at the socket. There should be 240 volts between the two slanted connections, and 120 volts between the center vertical connection (neutral/ground) and either slanted connection. I'm guessing that the 120 volt motor has 240 volts across it accounting for the fast drum speed. If the socket checks ok, check the wiring of the cord inside the dryer. The center wire of the cord should go to case ground. Hope the motor wasn't damaged.
Posted on Jul 14, 2009
Tumble dryer does not work. Doesn't heat up enough to dry clothes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Oct 04, 2014 | Dryers
What might be wrong with my Kenmore dryer which doesnt heat? The drum turns but will not heat.
GOD IS STILL GOOD !!!!
Sep 29, 2014 | Dryers
Why does bosch condensor sensor dryer not heat
Sep 09, 2014 | Bosch 422202 Clothes Dryer Moisture Sensor...
Leq1452kso dryer is not drying my clothes
Sep 09, 2014 | Dryers
What do i need to replace if dryer sensor stops cycle before clothes are dry
Jun 21, 2014 | Kenmore 63942 Dryer
Kenmore 796.69278000
May 26, 2014 | Kenmore Dryers
Dryer is heating but not blowing out
Apr 03, 2014 | Frigidaire Dryer Laundry Center Service...
Ariston AS66VXNA dryer - everything works but no heat- looking for a schematic to check out and troubleshoot - where can I get detailed schematic?
You can find a manual for your model here>>>>>>>>> http://laundry.manualsonline.com/manuals/mfg/ariston/asl70c_1.html Let me ad that you may have just one side of the 240 volt circuit breaker or fuse set tripped or blown allowing all of the electronic functions, but not allowing the full 240 volts across the heating element. One way is to check the fuse box first and then proceed to measure voltage across the heating element after turning on the dryer. Please use caution while doing this. Ariston Clothes Dryer User Manual ManualsOnline com
Jan 17, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
Seem to all of the sudden have problem when dryer gets warm the breaker trips? anyone know why that might be.dryer has been on the same outlet for 2 years.
Hi, When a breaker starts to trip on any appliance, it is drawing more amps then the unit is rated for. It should have a double pole 30 amp breaker if it is a 240 volt dryer.The first thing I would check would be the breaker and the 2 hot wires feeding it. Over the years, the wiring sometimes loosens up due to heat and they may be loose and just need to be tightened up. If you turn the breaker off, it kills the voltage to the wires going into it and you can then tighten them. If you are not comfortable doing this, maybe you know someone that can help you out.Also, overloading the dryer with a lot of cloths will cause the breaker to trip. I am sure that after 2 or more years that you are aware of this, just another cause.You may also have a problem in the motor, which draw a lot of amps if it over heats.You may have a lot of lint build-up around the motor and heating elements that should be cleaned out by removing the back of the dryer. Be sure the power is off before though. Try running the dryer with no cloths in it to see if the breaker still trips.If it still trips, I would say you are loosing the motor, but would check the breaker anyway. Please let me know what you find.
Sincerely, shastalaker7
Oct 31, 2009 | Dryers
Cloths dryer problem
ok " your dryer should have it's own line, make sure nothing else is pluged into that line.
may have other devices drawing amps.
Jan 16, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
119 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
