Question about Mitsubishi WS-65511 65" Rear Projection Television
Unit will not come on when pushing the power button on the TV or the remote. Checked power source and pushed reset button. Any Ideas?
  • 67 Answers
Yea this pictilar model kwon for this it is the vertical drive ic i recommend checkint it fist check fuses may fix ur problem impossible to geusse
Posted on Jul 25, 2009
I have a akai 61 inch dlp tv, my son turned it off went back 1 hour later tv would not come on with remote or by push button on front, checked to make sure power was in cord to back of tv, any ideas what...
I'm assuming that no lights are blinking on the front of the tv and the bulb is in god working order - it has been replaced recently. In that case the tv will have to be opened and the voltages on the power source tested, starting with the ones on the main switching transistor, followed by the ones on the output rails - a good voltmeter will have to be used. If all are there then check the voltage going to the
Jul 29, 2011 | Akai PT61DL34 Television
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
My two year old son pushed a button on the remote and now our HD Samsung tv says Weak or no signal. We have tried everything including reseting it. Do you have a solution, please?
try going to the tv itself and push the source/input button. you should go to the correct source to get your picture back. try looking for the input or source button on the remote as well. that should do the trick -gab
Oct 18, 2010 | Samsung LN-S4092D 40 in. LCD HDTV
What channel should I turn my tv to? i have dish
If you have Dish, your remote should have a selection for TV/VIDEO located just under the SAT and TV buttons on the upper left of the remote. Push the TV button, push the TV/VIDEO button, and you should be able to reset the TV to Satellite.
After you've reset the TV, remember to push the SAT button on the upper left to allow your remote to access the satellite.
Jan 28, 2010 | Nintendo Wii Console
I push the on button and nothing happens. is it
Even though a lot of things might have gone wrong and caused this, especially if where you place the System is not well ventilated, and the CPU becomes very hot, it shuts down automatically...and you will have to wait for a few moments, get a cool environment and power it on. but I will also try and tell you some troubleshooting steps that you can try.
Since you have already checked the power source and all is Ok, then try this out:
Disconnect your PowerPack(Power Supply Unit) from the CPU and try to power your PC with another Power Pack (Power Supply Unit), that you are very sure is working.
If it powers up, then just get a new Power Pack(Power Supply Unit) for system.
If you cant do this yourself, just get a good technician to do it for you.
Try this first and let me know how it goes, so as to know the next step.
Hope this helps.
Nov 21, 2009 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
I have model VS50609 and it will not power on.
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Craftsman Garage door opener not working
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
RCA systemlink 3 remote
My friend you gotta turn on manually your tv first.Then push and hold until the indicator light lights,then release the code search button now push and release the Tv button after that you gotta push and release the power button until the Tv turns off then you push the enter button to save the code.Good luck.
May 10, 2008 | RCA Universal Remote Control
TV won't turn on
Some times the power button gets stuck sideways when you push it, leaving it half pushed in. Just be sure the power button is able to move in and out freeley, use a small knife to free it if stuck. Darren
Apr 25, 2007 | Sanyo DS25390 TV
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
175 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
