Lcd TV display is dark
I have an 26" lcd tv, the display is dark across the whole screen even though both brightness and contrat are at full??
if you use PIP then the picture in the small screen is perfect.
I think there must be a problem with something but I don't know where to start?
The LCD TV is a Saisho SGX26 I think
Ask the same question on a more useful website....
Posted on Jan 15, 2010
Hi, Sony kdl-46Z4100 - no standby light when
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2017 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
My Sony Trinatron has suddenly displayed a dark screen on all channels. You can see the picture but looks like it's nightime. I've tried ajusting the brightness but no result.
does the TV bring out sound even as the screen display is dark?
Problem should be from the TV lamp/bulb. When a TV bulb/lamp is dying, it makes the pictire on the screen become dark and very hard to see.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
I own a 5 year old 40" sony bravia lcd tv, When
This sounds like what I managed to do to my screen, even though I knew better. Is there any chance you layed the screen face down at some time?
Even though you can still watch it OK, you probably have hairline fractures in the screen face (NOT the screen itself- be thankful for that- the cracks are in the screen coating). LCD screens are a very thin glass laminate with a thin protective glass-like coating. When they are laid flat (like I did to connect cables) if the screen bears any weight, microcracks develop on the front of the screen.
I am sorry to say that the effect is permanent.
Feb 24, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black line (strip of pixels not working) horizontal across screen
If a whole line of pixels is dark, you've got a bad transistor in what's called a "Passive Matrix" display. For your future purchasing decisions, while an "Active Matrix" display costs a little more, it has individual transistors for each pixel, rather than one per row and column, so when a transistor goes bad, it only turns one pixel black rather than a whole row or column.
Sep 12, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Jul 18, 2009 | Element Electronics FLX2211B 22 in. LCD TV
TO GET THE DIFFRENT BETWEEN LCD VS PLASMA
LCD
LCD stands for liquid crystal display. These types of displays have been around for awhile and are commonly used with computers. One reason for their big popularity is the ability to produces a better picture than CRT monitors but also being much thinner.
Pro’s
  • Low Energy Consumption – LCD monitors use very low amounts of power. This is why it is very commonly used in battery powered devices.
  • LCD screens also reduce the amount of glare on the screen which can be very beneficial if your TV is in a room with lots of light.
  • If an image is left on the screen too long, LCD screens are less likely to experience the image being burned into the screen. If this does occur, it’s easier to repair than other types of TV’s.
Con’s
  • The viewing angle of an LCD TV is typically not as great as Plasma but the difference is not great enough to make a huge difference.
  • LCD TV’s can sometimes get dead pixels which aren’t typically covered under warranty. Although they are very small, they can become very annoying.
  • Brightness levels aren’t as great as Plasma and it’s not possible to display darks quite as dark.
Plasma
Plasma technology hasn’t been as widely used as LCD in previous years but has become very popular in large HDTV’s. Although they have historically been more expensive than LCD TV’s, they are becoming more comparable in price.
Pro’s
  • Brightness and color are the major advantages of Plasma TV’s. They produce rich colors along with very deep blacks.
  • Their wide viewing angles allow more people to be able to watch TV comfortably.
  • The pixels of Plasma TV’s are lit individually unlike LCD screens. Because of this feature, the pixels can be completely turned off to display truck black colors.
Con’s
  • The lifespan of a Plasma TV is typically shorter than other types of TV’s. The lifespan can be extended by turning down the brightness of the screen.
  • Plasma TV’s are more susceptible to screen burn-in where an image is “burnt” onto the screen when left on the screen too long such as a network logo in the bottom right corner of the screen.
  • Plasma TV’s require a panel of glass to cover it. This glass can reflect light and make it difficult to see the picture. If placed in a dark room, this typically isn’t an issue.
Jun 09, 2009 | LG Televison & Video
LCD TV has sound but no picture.
Shine a small bright light at the screen when on and see if you can see a faint picture in the dark screen. If you can then your backlighting is not functioning due to ccfl (inverter), power supply, or back light lamps.
Mar 27, 2009 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
